2014 Prius 19k miles P0A0F P3190 P0401
Discussion in 'Gen 3 Prius Main Forum' started by Sharnold, Sep 12, 2019.
  1. Sharnold
    Sharnold Active Member
    400
    126
    Alabama
    Egr valve was already checked along with the tube and ports as far as the pcv I'm beginning to get to the point of pulling it
  2. Sharnold
    400
    126
    Alabama
    I've had it to the side working on others the last 2 days I think I'm going to pull everything.... air box, throttle body, intake, egr, pcv valve, all hoses, 02 sensors, and check the whole harness....... its gotta have an issue somewhere and I've already went through most of it already but surging and roughly idling has to do with insufficient air/fuel ratio and it drives too smoothly with no issue once you get to driving it. It's only doing this when shutting off and restarting
  3. vvillovv
    vvillovv Senior Member
    4,321
    1,510
    NY
    Olathe shop lists some common issues
    But they are not rebuild issues
    PM me for the link or do your own search
    may help at least give you some clues where to look
    regarding those three codes.
  4. Sharnold
    400
    126
    Alabama
    vvillovv and Mendel Leisk like this.
  5. Mendel Leisk
    41,464
    How the heck would that happen? (n)
    Part no: 12261-37060
    (I cut mine for Oil Catch Can installed, bought an extra for trade-in time.)
  6. Sharnold
    400
    126
    Alabama
    It was a rebuilt title car someone tore the line coming off the pcv. Even had oil collecting on the splash guards..... all of this for improper air/vacuum
  7. Mendel Leisk
    41,464
    Nice simple catch, anyway. :)
  8. ASRDogman
    ASRDogman Senior Member
    7,597
    3,916
    Perhaps I "missread" a previous post. But didn't you say you removed the intake and cleaned the egr ports,
    and the cleared out the oil? When you cleaned the egr system, including cleaning the cooler?
    I figured the pcv valve was not working properly, and/or a hose was cracked. I'm very happy you found it!
    And that you were able to repair it. Bet it runs great now doesn't it? :)
  9. Sharnold
    400
    126
    Alabama
    Yes but unfortunately my mistake was not pulling the pcv the hose was cracked right on the fitting...... lesson learned
  10. ASRDogman
    7,597
    3,916
    Not a biggie. We've all done stuff like that. "Assuming" is never good. :)
    It pisses me off when I find something simple like that, that I KNEW I should have known....
    Just be glad it wasn't worse....
  11. vvillovv
    4,321
    1,510
    NY
    Many if not all hybrids behave like that. One error detected can sometimes trip several or many unrelated codes. So keeping track of hard to find solutions to multiple code conditions can be tricky and well worth logging if the shop repairs a lot of them.
