2014 Prius 2 with water dripping on the ground.
Discussion in 'Gen 3 Prius Main Forum' started by Kevin Drake, Oct 7, 2022.
  1. Kevin Drake
    Kevin Drake New Member
    Michigan
    Water drips on the ground after driving and NOT using the AC. It is clear water. If it was in the radiator, it would be freezing solid here in Michigan soon. Ant ideas?
    Thanks
  2. JC91006
    16,936
    8,647
    Where is it dripping from? If there's moisture on the car when you drive, it would just settle and drip onto the ground to drain.
  3. ChapmanF
    19,012
    Any chance the defroster was in use?
    fuzzy1 and Mendel Leisk like this.
  4. ttou68
    ttou68 Active Member
    351
    211
    Perhaps by identifying the drain/water leak location could help find the the root cause?
  5. Mendel Leisk
    42,332
    On our (Canadian) 2010, if vent mode is set to heat/defog, the AC compressor cycles. Confirmed with ScanGauge.
    #5 Mendel Leisk, Oct 8, 2022
  6. bisco
    52,838
    is the washer fluid blue?
  7. Kevin Drake
    Michigan
    When I opened the service access area where you drain the oil, it was dripping out of there.
  8. Kevin Drake
    Michigan
    I believe so. The water on the ground is about a foot and a half in diameter. The car has never done this before.
  9. ChapmanF
    19,012
    The defroster setting uses the air conditioner, in order to remove moisture from the air so it does not condense on the windshield. The removed moisture drips out the bottom of the car.
  10. Kevin Drake
    Michigan
    Thank you! That makes sense.
