2014 Prius 3 Bucking
Discussion in 'Gen 3 Prius Technical Discussion' started by Benjamin Barnes, Jan 20, 2024.
  1. Benjamin Barnes
    Benjamin Barnes New Member
    Nashville, North Carolina
    I purchased my Prius 3 six years ago used with 64K miles. It now has 192K miles and has needed nothing except rear calipers. Recently I have noticed it bucking or trailering at low speeds. Barely noticeable but I can feel it. It idles smoothly and I don't notice it at full throttle. Mainly at 45 mph and below. While starting it has sounded like one cylinder was skipping but this has only happened 4 or 5 times since I bought it and it hasn't done this in over a year, original spark plugs.
    Ideas?
    Thanks
  2. JC91006
    16,936
    8,647
    The spark plugs should be changed, rated for 120k miles. That could be your problem
  3. Eddie25
    Eddie25 Active Member
    503
    213
    MI
    This could be the ol' clogged intake manifold EGR runner. You get misfires in situations where the EGR is open, so I think that means not at idle, and also not at decent throttle. It'll be only when the engine kicks on while driving, but at lighter loads.
    From my experience and what I believe is mostly the case is that cylinder #1 runner gets clogged and creates a situation that causes cylinder #4 to get extra hot (or extra gasses... or something), so a quick check is to see if cylinder #4 spark plug is darker than the rest (might as well check them all at this point). If it comes to this, you've opened up the EGR system can of worms and might as well clean the whole system. Check out the links in Mendel's signature.
    CR94 likes this.
  4. Mendel Leisk
    42,310
    Ping
    (On phone turn it landscape to see signature)
