2014 Prius 4 Bluetooth suddenly low volume
Discussion in 'Gen 3 Prius Main Forum' started by Spooled, Apr 15, 2021.
  1. Spooled
    Spooled Member
    142
    26
    Concord, CA
    So lately my Prius stopped transmitting my phone calls at a reasonable volume.
    I unpaired and repaired my phone.
    It’s not NOT working volume is just very low. But is paired and working. Music volume is no problem.
    ideas?
  2. PriusCamper
    PriusCamper Senior Member
    13,465
    5,432
    Pacific Northwest, USA
    Volume control on phone?
    PosauneGuy likes this.
  3. Spooled
    Spooled Member
    142
    26
    Concord, CA
    Thanks. I checked the pre signal before pulling out my laptop, logging in, and posting here. Still not working
  4. PriusCamper
    13,465
    5,432
  5. Spooled
    Spooled Member
    142
    26
    Concord, CA
  6. sLick415
    sLick415 Member
    214
    55
    San Francisco, CA
    Try disconnecting the 12v battery for 30 secs. Your presets will be gone.
    PriusCamper likes this.
  7. Spooled
    Spooled Member
    142
    26
    Concord, CA
    what’s the thinking behind this? The old turn it off and on again?
  8. PriusCamper
    13,465
    5,432
    It's same thing as rebooting your personal computer... It resets all the systems so whatever caused your volume to go down will be wiped away as a setting and it will revert back to original setting.
    sLick415 likes this.
  9. Spooled
    Spooled Member
    142
    26
    Concord, CA
    i have not changed any settings..what setting do you think would cause this issue?
  10. PriusCamper
    13,465
    5,432
    Would you say the same thing if tech support asked you to reboot your personal computer to see if your problems go away? Because that's the same thing you're doing by disconnecting the 12 volt battery.
  11. nicoj36
    nicoj36 Active Member
    518
    162
    Try pressing down and holding the radio’s power button for 20+ secs to reset it.
