2014 Prius AC No refrigeration
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by wukong sun, Apr 23, 2025.
  1. wukong sun
    wukong sun Junior Member
    66
    I just bought a used Prius. When I tested it, the air conditioner worked.
    One month after I bought it, I was waiting for someone in the car and the air conditioner worked fine.
    Later, it stopped cooling. Maybe it even felt like it was blowing hot air.
    I searched the forum and read a lot, and I felt dizzy.
    I tried to read the fault code and it showed 00.
    Now I suspect
    1 The hot and cold mixing damper because I really felt that there was a little hot air.
    2 The low-voltage circuit plug is prone to problems.
    Newbie, please guide
  2. wukong sun
    66
    Supplement 2
    Once it didn't cool
    I tested it again and it worked again
    I forgot which thread said that after more than 100,000 miles
    The low-pressure plug of the compressor is of poor quality
    It is easy to have problems
  3. MAX2
    MAX2 Senior Member
    1,436
    490
    101
    Third planet from the Sun
    Try to diagnose the car systems with the help of OBDII scanner and the program in the phone or find the Techstream cable and program for diagnostics of Toyota cars.
    Your problem may return.
  4. Mendel Leisk
    42,301
    Consider getting an “AC Service” at dealership?
    Grit likes this.
  5. BiomedO1
    BiomedO1 Senior Member
    4,550
    2,393
    Left Coast
    IMHO; get the system professionally diagnosed. It isn't uncommon for cars of that age to lose enough Freon from the system, though seepage, to become intermittent.
    Hope this helps......
