2014 prius battery case impossible to remove
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by saltdiscus, Dec 5, 2016.
  1. saltdiscus
    saltdiscus Member
    198
    89
    US
    HI
    After 3 hour of frustration to remove this small black cover i just gave up.I did tried everything under the sun but still cant remove it.Is this stuck or unremoveable? Can someone plz post a video or pic instruction to prove my dumbness because i ll just cut the cover with dremel and buy the replacement later.
    thanks.
    ; [​IMG]
    #1 saltdiscus, Dec 5, 2016
  2. mrbigh
    3,686
    699
    Long Island, NY
    Can you explain why you want to remove it?
  3. saltdiscus
    saltdiscus Member
    198
    89
    US
    ohh its for hid relay harness negative wiring as someone posted here before.I tried for 3 hour in this cold winter but just couldnt remove it.
  4. StarCaller
    StarCaller Senior Member
    1,280
    732
    Cedar Crest, NM, USA
    there's a tab to push IN, then you have to pull the cover straight up /
  5. saltdiscus
    saltdiscus Member
    198
    89
    US
    Which tab? The center 2 tab which need to be pull together or push in?
  6. jzchen
    jzchen Newbie!
    3,316
    1,021
    Arcadia, CA
    It's been a long time since I got it up, but I believe it's the one towards the very bottom on the picture.
    MT2L03 ?
