2014 Prius battery reset **URGENT**
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by aizaz.arshad, Mar 18, 2020.
Tags:
  1. aizaz.arshad
    aizaz.arshad New Member
    Pakistan
    Hey everyone!
    it's been a month now that I was getting this message
    "cooling performance of the hybrid battery is low consult a dealer" so I took the terminals out of the battery and plugged them in after a couple of minutes. The message went away however when I reversed the vehicle I don't see the guidelines when turning the wheels.
    Please help what should I do.
  2. Grit
    Grit Senior Member
    6,577
    4,229
    Wilkes Land
    Were the guidelines turning with the steering wheel before the terminals were unplugged?
  3. Aaron Vitolins
    Aaron Vitolins Senior Member
    1,612
    1,144
    Franklin TN
    It might be in the settings on the touchscreen. Also, did you clean your hybrid battery fan? If not, you need to clean it. It gives a warning for a reason!
  4. john1701a
    john1701a Prius Guru
    12,840
    5,311
    58
    That could be an ordinary blockage/impairment message. I got something to that effect back on an extremely hot day when someone sitting in back covered up the intake vent for the battery-pack. The system detected the problem and displayed a warning on the screen. Check to make sure air is able to pass through.
    Robert Holt likes this.
  5. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,804
    2017 Prius c
    A problem was indicated.
    That problem should be FIXED.
    Removing the power from the computers so that the error indication is erased is ***NOT*** fixing the problem.
    You need to forget about the guide lines in the camera for a while and get the battery cooling system checked and probably cleaned.
    Aaron Vitolins likes this.
  6. StarCaller
    StarCaller Senior Member
    1,283
    732
    Cedar Crest, NM, USA
    it's kinda hard to follow the 'logic' of trying to reset something when an overheating alarm shows up & it puzzles me that the missing guide lines are your top priority instead of your real problem /
  7. Grit
    Grit Senior Member
    6,577
    4,229
    Wilkes Land
    Perhaps OP is not a skilled parallel Parker. The cost of repair when smashing into other vehicles when parallel parking may exceed cost of cleaning fan which can be deferred.
    I only parallel park when I’m at SF other wise i don’t parallel park at all.
