2014 Prius C 4 fog lights
Discussion in 'Prius c Accessories and Modifications' started by Kodiak211, Jan 27, 2023.
  1. Kodiak211
    Kodiak211 New Member
    2014 Prius c
    How do you run a wire through the firewall? I'm looking to add some fog lights to the car. But can't seem to find a way through the fire wall of the 2014 Prius C 4
  2. PriusCamper
    PriusCamper Senior Member
    13,472
    5,439
    Pacific Northwest, USA
    There should be more than one grommet if you follow the wiring harness... Otherwise just drill your own in a place where you know drill won't run into anything and then add a grommet.
    Kodiak211 likes this.
  3. Pacific Northwest
    Pacific Northwest New Member
    24
    Portland Oregon
    I'm in the same situation.. everything is to tight that it's hard to see where a good spot to drill through.
    It also appears that drilling would have to be from inside the car toward the engine compartment.
  4. PriusCamper
    13,472
    5,439
    If you can get a right angle drill or right angle drill adapter you'll likely find a spot under the driver's side dash above the pedals.
    Pacific Northwest likes this.
  5. Pacific Northwest
    24
    Portland Oregon
    I'll look into that... how do you like the Red Bullet Solenoid?.. Was thinking about getting one.
  6. PriusCamper
    13,472
    5,439
    I thought they were worth it for a bit over $100... But now that they are closer to $200 I'm a bit more skeptical. Once I get my project Prius ready to sell I'll put it on that one and revert back to OEM on the daily driver to see how long I can go without it. It's definitely helpful at partially mitigating what happens with Prius' awful lag time for acceleration when you pull out into traffic...
  7. Pacific Northwest
    24
    Portland Oregon
    For sure... thanks for this info!
