2014 Prius C: Having trouble starting
Discussion in 'Prius c Care, Maintenance and Troubleshooting' started by AllisonMA, Feb 14, 2020.
  1. AllisonMA
    AllisonMA New Member
    Boston MA
    2014 Prius c
    Hey everyone, I'm hoping you can help since so far the dealership seems even more confused than I am.
    A few weeks ago my 2014 Prius c (55,000 miles) started not starting until multiple attempts. The car unlocks electronically, the lights come on (although dim) and when I turn the key in the ignition, first the check engine light comes on and nothing else happens. The next few times I turn the key more lights on the dashboard start lighting up, but the car never fully starts up. Then eventually, after 10-15 tries (with various attempts to reset like getting out of the car and locking and unlocking it, messing with the headlights, shifting) the car starts, and drives fine, and even starts again 2-3 hours later with no issues. Then, after letting it sit for a few days, the next time I try to start it the same thing happens again. Today, the car dashboard came up with a lot of the warning lights still on, but every time I pressed the breaks or tried to shift it seemed like it rebooted: the screen went blank, then all the lights came back up again. The weird thing that happens during this is that the screen displays the stats (distance, time and MPG) from the last time it was driven, like it thinks it never turned off.
    I took it to the dealer today (needed 55,000 mile service anyway) and first they didn't believe me (from the notes they wrote it looked like they thought I didn't know how to shift the car), then when I tried to take the car it wouldn't start properly and they seemed very confused and worried. The guy mentioned something about how the cover on the shift lock override button was missing, but I'm pretty sure that's been missing for a while now and these problems are quite recent.
    They also originally tried to get me to buy a new battery, but the last service I had last summer they told me the battery was fine. And then when I had the guy get in my car and see was was actually happening he seemed convinced it wasn't the battery. I do park outside (but it's been such a mild winter) and drive ~2 times a week for ~20 minutes at a time, so I wouldn't be shocked if it's the battery, but I'm skeptical, and I don't want to buy a new battery if mine is fine. They checked it today and said it was at 50% charge.
    I'd love insight into what it might be, or things I can do to diagnose further! I'm worried it's a software issue, and that I'll spend a bunch of money because the mechanics keep diagnosing mechanical issues, but no dash lights are on, so I'm not sure how to diagnose that.
  2. iceman13
    iceman13 Member
    134
    102
    US
    2014 Prius c
    What you describe is exactly what happens when you have a bad 12v battery.
    Montgomery and dig4dirt like this.
  3. dubit
    dubit Senior Member
    850
    538
    23
    Indiana
    2016 Prius c
    I agree. Classic sign of a 12v battery going bad.
  4. Leadfoot J. McCoalroller
    6,803
    6,454
    Pennsylvania
    2018 Prius c
    50% = dead in one of these. Get a new battery. Unfortunately they are pricey ($220 and up plus labor) but the symptoms fit and the calendar agrees (2020 - 2014 = 6 years) it's time for a new 12v battery.
    There probably isn't anything else wrong with the car but you're not likely to get a straight answer out of the diagnostic computer until there's enough electricity to boot properly.
  5. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,782
    2017 Prius c
  6. bisco
    48,946
    Put a charge on her and see if she holds
  7. Lydia Corum
    Lydia Corum New Member
    california
    Four Touring
    I have had the same problem, I know what you are talking about. Put a charge on the battery, take it for a long drive, it does great the next day. Then 2 days later it won't start again. the lights come on, do not dim, the ready light comes on, I shift back and forth, retry to get it started and it will not. Put it back on the charger, though the battery indicator says full, it starts. I drive it for 50 miles or more, it does fine the next day, if I leave it 2 days it won't start again. HELP
  8. sam spade 2
    7,035
    2,782
    2017 Prius c
    Help has already been provided in the first 6 posts in this thread.
    The odds are EXTREMELY HIGH that your battery is just worn out. That's the way a worn out battery acts.
    The onboard charging system in the car is not designed to re-charge a completely dead battery either.
    You NEED to have the battery fully charged and tested.......or if it is over 5 years old, just get a new one.
    The new one must be fully charged before use.
    And then the charging voltage needs to be checked too.
    Montgomery likes this.
  9. bisco
    48,946
    2012? i replaced mine last year. whacoo waitin' for girl?
  10. Montgomery
    Montgomery Senior Member
    2,254
    2,233
    Orange County, CA
    Getting mine next week. Hitting 5 years next week when I bought the car new.
