2014 Prius C intake air temperature sensor location
Discussion in 'Prius c Care, Maintenance and Troubleshooting' started by electricdjinn, Oct 10, 2022.
  1. electricdjinn
    electricdjinn New Member
    Boston
    2014 Prius c
    Check engine is on, code reader says intake air temp sensor stuck high (-39C or something like that). I have a new sensor, but don't know where the old one is to replace it! Does anyone know or have access to service manuals to point me in the right direction?
  2. ivanhoe
    ivanhoe Member
    71
    28
    2015 Prius v wagon
    Is this the part you bought, if not let us know the part number.
    22204-0V010
  3. ChapmanF
    18,944
    The intake air temperature sensor is part of the mass airflow (MAF) sensor assembly. Is that what you bought?
    If you follow the intake air ductwork on the front of the engine, you will find where the MAF sensor goes.
  4. tungm
    tungm Junior Member
    Zimbabwe
    2014 Aqua
    As mentioned by ChapmanF, the intake air temperature sensor is part of the MAF. For the 2014 Prius C it is mounted on the air box just before it joins the duct going to the throttle body. It is the first sensor with an electrical connector on it with 2 Philips screws
