2014 Prius C Motorcycle Carrier
Discussion in 'Prius c Main Forum' started by William C Adams, Jan 29, 2021.
  1. William C Adams
    William C Adams Junior Member
    St. George, UT
    2014 Prius c
    ***HELP ***
    I know I won't get very good gas mileage on my Pri Pri however, I need to transport a BMW F650cc motorcycle from Utah to California (400 miles).
    Can my Prius C III handle a carrier of a 400 lb. motorcycle or not?
    What do you suggest?
    52,863
    you might be better off pulling the c with the bmw :cool:
    jwl2000, topshot and RobAustin like this.
  3. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,804
    2017 Prius c
    The type shown should be fine.
    Be sure to check the BMW recommendation about towing though.
    An even better option: RIDE it there.
    The cost of the carrier and hitch will be more than a bus ticket back to get it.
  4. William C Adams
    St. George, UT
    2014 Prius c
    I'm going to add this ( extension piece so I dont hit the plastic molding
    then add this and take the weight off of the rear of the prius c for my 400 lb. bike and this will rise it up and lock in place.
    #4 William C Adams, Feb 1, 2021
  5. Leadfoot J. McCoalroller
    8,291
    7,808
    Pennsylvania
    2018 Prius c
    I've pulled small trailers with my c, it works fine.
    Note that if you're pulling 400lb that cuts the in-the-car payload rating down to about 600lbs. Deduct your own weight from that, and what remains is your "inside the car" allowance for passengers or cargo. It goes fast.
    You really do not want to push that limit on mountainous routes. Your itinerary certainly could include some mountain driving; best to check that in advance.
  6. Danny13pruisc3
    175
    28
    maryland
    what did you end up doing?
  7. sam spade 2
    7,035
    2,804
    2017 Prius c
    He has not been back for 6 months.
  8. "A"
    "A" Junior Member
    brooklyn
    AFAIK, for those front wheel chock motorcycle hitch carrier, you need a class 2 (2") hitch.
    I think Prius C only has class 1 (1-1/4") hitch available.
    A BMW F650GS or G650X motorcycle are under 500 lb., with rear wheel contacting the ground, likely only 200 lb. on the tongue of the hitch.
    By the time you tow the motorcycle from UT to CA , you might need a new rear tire for the motorcycle.
  9. Danny13pruisc3
    175
    28
    maryland
    BMW likely has no recommendation about towing with the rear wheel on the ground.
    The bus ticket will be a one time fee and use.. but if you get the hitch and trailer, it will save money in the long
    run using it for other things.
    I recommend buying a nice cheap 4x8 trailer though. I have both but i would use the front wheel grabber just for
    local tows. for 400 miles, i'd rather have it more secure on a 4x8 preferably with a "locking" chock. Those hold the bike so well.
  10. Danny13pruisc3
    175
    28
    maryland
    yes but sometimes people get email notifications on thread updates so he might be back.
  11. Danny13pruisc3
    175
    28
    maryland
    They make adapters to go from 1 1/4 to 2 inches.. and now the adapers have a much needed rise to them. They are much better than the straight ones.
    The best scenario would be to buy a small trailer 4x8 and use a locking wheel chock and strap it down at 4 points. It would be more secure and less tongue weight and no wear on the rear tire, chain, and sprockets. Could always sell the trailer setup later if no room to store it. As a motorcycle owner though, it's best to keep it if you ever want ot drop yoru car or bike off somewhere.
