2014 Prius C Transaxel oil change
Discussion in 'Prius c Care, Maintenance and Troubleshooting' started by edteach, Jul 26, 2018.
  1. edteach
    edteach Junior Member
    37
    sarasota florida
    2014 Prius c
    I have 75k on my 2014 Prius C. I ordered a new set of Denso Iridium plugs and need to change the Transaxel oil. I know I need to get the Toyota oil, so I have a few questions if anyone can help. How many quarts does it take? Is Toyota dealer the only place to get it and what is it called?, I need to get an oil pump from what I see as the plugs are not in a position to put a quart can. What size is the hex wrench for the plugs? Thanks for any help.
  2. zen_
    zen_ Junior Member
    29
    Midwest
    2014 Prius c
    How to: Change Transmission Fluid ATF WS | PriusChat
    I followed that guide, except I just used a long length of vinyl hose to refill. A pump would probably be easier w/o the risk of the hose popping out, and it's easier to keep an eye on when the transmission is full (overflowing). I also used two new crush washers on the plugs, which are P/N 90430-18008, as replacing used crush washers is always best practice. You can get 4 quarts of ATF WS + a 10 pack of washers on Amazon for ~$45...not sure about dealer price.
    Wish I hand't accidentally dumped my shot glass sample of old fluid on the floor. It was very, very dark red after only 35K miles. Much to my surprise, the transmission seems smoother after replacing the fluid. As with a traditional automatic, it was starting to feel grabby in hot weather crawling through city traffic. Not sure why that is, or if I was just imagining things.
  3. dubit
    dubit Senior Member
    850
    538
    23
    Indiana
    2016 Prius c
    Zen, you've got me wondering if I should change the fluid in my C. I'm just about to hit 23k. What is the recommended interval for that change?
  4. Raytheeagle
    Raytheeagle Senior Member
    11,267
    15,526
    Bay Area, California
    2019 Prius Prime
    If it’s like the liftback, it’s not mentioned to be changed:rolleyes:.
    I did our 2017 RX450h trans axles at 6800 miles and the front transaxle had a film of metallics adhered to the magnetic plug ;).
    Glad I did it and when we replace our 2010 liftback at some point, the next Prius that replaces it will also get the same treatment (y).
    #4 Raytheeagle, Jul 28, 2018
    dubit likes this.
  5. zen_
    zen_ Junior Member
    29
    Midwest
    2014 Prius c
    As with most late model vehicles, there is no scheduled interval by the manufacturer because the original fluid will go to the end of the warranty, at which point the manufacturer doesn't care. The dealer will be happy to schedule an appointment for a replacement transmission after that though!
    30K mile intervals seems prudent to me. Just not worth skimping $35 in fluid + $2 in washers + 30 minutes of time to keep the transmission happy for long term owners. If you synchronize it with a 5 or 10K mile oil change interval, then it's even less time.
    dubit likes this.
  6. ztanos
    ztanos All-around Geek!
    3,339
    1,150
    40
    Cumming, Georgia
    I asked my dealer how much this would cost and he very nearly refused to give me a quote on it... surprisingly. I leaned on him a bit about it and he finally came up with a price of ~$200.
    He kept emphasizing that it isn't necessary on these transmissions. I just rolled over 100k and will do it for the first time here shortly... I need a free weekend to do it.
  7. Mendel Leisk
    42,254
    That's too much, and makes you wonder if they even know what they're doing. Unfortunately I don't have a Prius c Repair Manual, but I'd speculate the procedure is very similar to 3rd gen Prius (attached).Take a preliminary look, see where the fill and drain bolts are. I would speculate you need:
    1. 4 quarts Toyota ATF WS
    2. Fill and drain bolt replacement washers (Not do or die, but if the parts department can find them I'd get them. If it's similar to 3rd gen Prius the two washers (and the bolts) are the same.
    3. Some sort of funnel with 3~4 foot hose extension: start long, and trim to suit when you use it. Save it for just that job, to avoid contamination.
    4. Ratchet wrench socket with 10 mm Hex drive (male). Stanley sells a set of these, with 10 mm size the largest.
    5. Torque wrench (3rd gen torque spec is 29 foot/pounds). (You can wing it, but torque wrench is the way to go, say a 3/8" drive.)
    6. Solid, long handle ratchet wrench or breaker bar. (just makes life easier, the fill and drain bolts can be a little stubborn to break loose. Start with the fill bolt, just in case...)
    7. Equipment/method for safely raising and levelling the car. When filling, proper level is achieved by filling (with the car level) until the fluid starts coming back out, so reasonably level is mandatory.
    Again, attachment is excerpt from regular 3rd gen Prius Repair Manual:
    ztanos likes this.
  8. ztanos
    3,339
    1,150
    40
    Cumming, Georgia
    Yeah, I laughed and told him it was a 30 min job if I were to do it... even less for them. I suspect he just didn't want to do it, for some reason... but that was honestly the reason I was asking is because I didn't want to do it. :D
  9. edteach
    37
    sarasota florida
    2014 Prius c
    The oil I took out was not burnt but it was dark red with a tinge of black to it. Glad I changed it. I could not get the car perfectly level but it was close. so when I finished I did the same in reverse and pumped in three more pumps of oil. Each pump is about Three table spoons.
