2014 Prius catch can optional
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by saltdiscus, Sep 20, 2021.
  1. saltdiscus
    saltdiscus Member
    198
    89
    US
    Hi
    I don’t have any problems with this engine and it’s 125k miles.Does 2014 need catch can installed?I am thinking of cleaning egr system and if it needs catch can then I want to install now.
    Thanks.
  2. tankyuong
    tankyuong Senior Member
    1,555
    662
    Central MO
    If you see oil in your throttle body then yes
  3. xliderider
    xliderider Senior Member
    8,140
    3,280
    Honolulu, HI
    Don't just clean the EGR cooler and EGR valve, clean the intake manifold and EGR passages in the intake manifold as well.
    Raytheeagle likes this.
  4. Raytheeagle
    Raytheeagle Senior Member
    11,269
    15,530
    Bay Area, California
    2019 Prius Prime
    I put an oil catch can on our 2019 Prime and it catches oil ;).
    So I'd say "yes" (y).
    xliderider likes this.
  5. Mendel Leisk
    42,368
    I remember the first time, looking through the throttle body, seeing the black mirror surface beyond, thinking what is that. That’s what an effective Oil Catch Can will partially quell.
    You’re due for full Exhaust Gas Recirculation cleaning too.
  6. saltdiscus
    saltdiscus Member
    198
    89
    US
    thanks for letting me know. I will put it next week .I guess buy it from Amazon.
  7. xliderider
    8,140
    3,280
    Honolulu, HI
    You're going to need better oil and fuel resistant hose than what comes with most catch cans from Amazon.
    Paul E. Highway and Raytheeagle like this.
  8. Mendel Leisk
    42,368
    3/8” ID SAE30R7 fuel line is good, readily available locally by the foot, at automotive specialty stores. Or …R6.
  9. saltdiscus
    saltdiscus Member
    198
    89
    US
    Thanks I’ll look for it.
  10. saltdiscus
    saltdiscus Member
    198
    89
    US
    Does anyone know where to buy mount for oil catch from nutz YouTube video?
  11. Mendel Leisk
    42,368
    The sun doesn't rise-and-set on having that, though I guess it would be nice.
    For a lot of cars, mostly North American, some of the more established OCC makers supply "kits". Basically they've researched optimum install location and plumbing, provide you with full instructions, all the necessary hose and fittings, and a mounting bracket.
    For the Prius that hasn't happened. IIRC @danlatu was the member that 3D modeled the bracket that @NutzAboutBolts used. But all sorts of mounting methods, and as many locations, have been used.
    FWIW, I mounted mine (a couple of Mororso 85474) on a bracket atop the lower front cross beam, under the intake manifold. That location is not readily accessible from above, suited for access during oil changes.
    That's just one example though. There's lots of simple-but-effective mounts. Another example: one or two have zip-tied an empty, open-topped tin can somewhere, then just dropped their can iinto it, relying on gravity to restrain it.
    Another clever location: on the front side of the engine, down lowish near the transaxle end, there's a blanking plate, covering the opening where the starter motor would be (when the Prius engine is employed in a regular Corolla). A mounting bracket can be incorporated into that plate, in several ways I think.
    This is the mother-of-all oil catch can threads, here:
    Oil Catch Can, Eliminate that knock! | PriusChat
    #11 Mendel Leisk, Sep 28, 2021
    Raytheeagle and xliderider like this.
  12. Raytheeagle
    11,269
    15,530
    2019 Prius Prime
    A good method:).
    I even did this on our Prime, just not zip tied or attached to the front cross member;).
    But now our Prime's engine doesn't activate much :whistle:.
    The benefits of charging at work and a commute inside of the EV range window(y).
