2014 prius key fob battery tray replacement?
Discussion in 'Prius v Audio and Electronics' started by njbdurango, Aug 3, 2025.
  1. njbdurango
    njbdurango New Member
    Tucson AZ
    2014 Prius v wagon
    Hello, Is anyone aware of somewhere to purchase the small black plastic battery tray that sits inside the keyfob and holds the battery? Mine has worn over time and I'm unable to find a replacement for this piece of the keyfob. If there is a common fix for this, please point me in the right direction.
    52,889
    can you find a cheap fob online and swap parts?
    Air_Boss likes this.
  3. njbdurango
    Tucson AZ
    2014 Prius v wagon
    As far as I know the replacement fob shell does not contain the inner plastic battery tray (which attached to the circuit board). Could be wrong though.
    52,889
