2014 Prius maintenance recommendations
Discussion in 'Gen 3 Prius Main Forum' started by JoySS, May 2, 2022.
Tags:
  1. JoySS
    JoySS Junior Member
    28
    Colorado
    I wanted to see if anyone had a recommendation list for maintenance on a 2014 Prius. I used to own a 2004 and someone awhile back posted a fantastic list of maintenance recommendations throughout the lifetime of the car for the 2nd gen.
    I do have the warranty & maintenance guide that comes with the car, however the list Im referring too went above and beyond for what's necessary and not necessary.
    The previous owner of my 2014 had an engine flush, cooling system drain/fill done at 45k.
    and the hybrid cooling system serviced, HV inverter drain/fill at 50k
    as well as a fuel injection service done at 60k.
    along with regular oil changes every 10k.
    Wondering since he had these done so early when I would do again?
    Thanks all!
  2. JC91006
    16,936
    8,647
    Whoever owned the car before you did a lot of unnecessary services, especially the coolant services at 45k and 50k. Did the previous owner service the car at the dealer? Hell of a job upselling to where ever the car was serviced. None of those services are recommended until well after 100k miles.
    The oil changes, I would start doing them at 5000 miles instead of 10000 miles. These cars start burning oil early and you can keep the car in much better running condition by doing the oil changes early (instead of the other services early)
  3. PriusCamper
    PriusCamper Senior Member
    13,455
    5,430
    Pacific Northwest, USA
    Check out the signature line on all @Mendel Leisk posts... It's a good list, but the links are outdated on it so you'll need to research additional instruction for some of them.
    52,848
    how many miles on her?
  5. JoySS
    JoySS Junior Member
    28
    Colorado
    85k
  6. JoySS
    JoySS Junior Member
    28
    Colorado
    They took the car to the dealer for pretty much everything, on time and perhaps overly pampered the car. Im grateful to have gotten a used car that was taken care of so well. I'll consider doing the oil changes every 5k instead. Im interested in seeing more info on why it's suggested to change at 5k rather than 10k, do you have any sources you respect and could share?
  7. JC91006
    16,936
    8,647
    The owners manual will have that info. There are special conditions that the car would require 5000 miles oil changes. The special condition really is suppose to be the norm. The 10000 miles oil changes should really be the "special condition", not the 5000 miles change. Not many people will fit into this category of 10000 miles oil changes (no short trips, no idling in traffic, mainly highway driving without traffic, etc). @Mendel Leisk should be able to tell you more, he changes his oil every half year and a couple thousand miles (following Toyota recommendations)
  8. bisco
    52,848
    your car is not due for anything major until 120,000 miles. the only extras we recommend here is tranny fluid change and egr cleaning, and now is a great time to do them.
    you can get a maintenance schedule at toyota.com/owners if you don't have one.
    do not take any dealer recommendations without asking here first. they are more interested in their bottom line than your cars health.
    when you have time, look into egr circuit cleaning, and also whether your car has the updated pistons and rings. they changed by vin number some time in 2014 production.
    also, it would be good to inspect the battery cooling fan and filter.
    JoySS and Mendel Leisk like this.
  9. Mdv55
    Mdv55 Active Member
    246
    181
    Boston
    Love it. On one hand we have a statement that maintenance was done that wasn't recommended by Toyota yet. On the other, we have a statement saying that things should be done that Toyota doesn't recommend at all.
    There is nothing wrong with changing the coolant at an earlier interval because time degrades it and not just relying on mileage.
    Plenty of people claim that 10k is too long for oil changes and say to change it earlier. Why isn't coolant viewed similarly?
  10. bisco
    52,848
    testing and experience
  11. JoySS
    JoySS Junior Member
    28
    Colorado
    All services including oil changes were done at the dealer.
  12. JoySS
    JoySS Junior Member
    28
    Colorado
    Thanks Bisco. My car is at 85k, so do you still recommend these extra's or after 120k? I will look into all this and consider doing.
    Thanks much!
  13. Mendel Leisk
    42,343
    EGR cleaning info in my signature.
    FWIW, spreadsheet format summary of the Toyota USA 3rd gen schedule attached:
  14. JC91006
    16,936
    8,647
    Coolant is a completely different fluid compared to an engine oil. Changing it early only can cause you problems if not done correctly. If the air is not taken out of the system correctly (and it's not that easy on a Prius), your car can overheat and you'll end up stranded and worst case needing a new engine. The manual for gen 2 Prius states to change is at 100k miles and then every 50k miles after that.
    The oil changes are not set at 10k miles per oil change. There's certain criterias that allow you to go that long safely. Most people will fall into the more "severe driving" criteria where you have to change the oil every 5000 miles.
  15. bisco
    52,848
    yes, the tranny fluid and egr asap, but no rush. it's always worth looking at the cooling fan and intake, just like the air and cabin filters
  16. Mdv55
    Mdv55 Active Member
    246
    181
    Boston
    There's ususlly a time component to coolant as well. It's easy to bleed air on 2011+ cars.
    I've done it twice now on my 2011 and it's cake compared to my GM truck.
