2014 Prius moldy air conditioner
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by PriusMaximus, Aug 8, 2014.
  1. PriusMaximus
    PriusMaximus Junior Member
    Columbia SC
    I just traded a 2010 Prius for a new 2014 Prius, and the new car has already developed a terrible a/c odor. My 2010 Prius never had this problem and I used recirculate all the time. A friend alerted me to this problem with the newer Prius, so I've been diligent about running the a/c on free flow, rather than recirculate. Is there anything I can make Toyota do, or any class action lawsuits?
  2. mrbigh
    3,686
    699
    Long Island, NY
    You have to be kidding...............
  3. PriusMaximus
    Columbia SC
    Why would I be kidding? I don't care to have a "dirty sock" smell in a brand new car.
  4. mrstop
    mrstop PWR Mode
    740
    329
    109
    Cincinnati, OH
    There have been several threads on the AC smell. Additionally, if you do a broader search you will find this is not unique to the Prius nor Toyota. You can take it into the Toyota dealer to see if they will clean your system. They will probably say this is normal...
    Anyway, here's the standard reco:
    1) When getting close to where you will be stopping, turn off the ac, put the mode in fresh air and turn up the fan speed. This will help dry out the evaporator so it doesn't develop funk.
    2) If the funk smell doesn't go away, you need to clean your evaporator. If you are moderately handy it is fairly easy to do yourself. I did it on mine using: Kool-It-Evaporator-Cleaner. You are supposed to insert the tube into the AC drain tube underneath the car. However, if I were to do it again, I would do it from inside the car as it should be easier to get the tube further into the evaporator. The drain tub runs behind the passenger side carpet.
    PriusMaximus likes this.
  5. bisco
    52,861
    try some baking soda in your cabin filter, or a charcoal filter.
  6. Jamesb93612
    Jamesb93612 Member
    133
    69
    Clovis, Ca
    I am a big fan of the charcoal filter. They are a little more expensive but I get them on Amazon. Also I find that changing them frequently helps to curb the smell from building up. Also I turn off my A/C about a block away from my destination and let the fresh air in.
  7. bisco
    52,861
    you got the O without the B.;)
  8. Mr.Electric
    Mr.Electric Member
    287
    106
    San Francisco
    Did the cleaning spray work?
  9. mrstop
    mrstop PWR Mode
    740
    329
    109
    Cincinnati, OH
    Yes, it worked pretty well. There was a slight odor remaining afterward, but I think this is because I did the cleaning from under the car. From what I can tell the evaporator is in the center of the car. Because of this the tube and spray have a long way to go before reaching the evaporator and it probably didn't do a full cleaning. Hence, my reco of spraying from inside the car (plus you get more visibility of what you are doing.
    I did the cleaning back in May and have not had any more funk smell come back. Even if I did, a $10 annual diy evap clean isn't too bad. The nice thing about the product I linked to is that it doesn't add a permanent scent. I have read complaints about other products, including what the dealers use, leaving an awful strong scent.
