2014 Prius not starting below 10 degrees, recommendation cca battery?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by iadss77, Feb 8, 2022.
  1. iadss77
    iadss77 Junior Member
    Cedar Rapids, IA
    I live in Iowa and I am having trouble starting my Prius under 10 degrees and we have had weeks at a time where it doesn't get above 10. I am shutting all radio, heat and lights off before shutting it off at night but every morning I have to use my jump box to get it started. I have taken to trying to drive a 20 mile route to try and charge the battery at night but it hasn't helped. I have taken it to multiple places to test the battery (less than 1 year old) and they all say it's fine but I was wonder if I need a battery with more cold cranking amps. I have looked around but the most I can find is 450. Does anyone have any suggestions? I am desperate and jumping it every morning is not acceptable anymore since my jump box will only work if it is connected directly to the battery so I have to crawl over the seats to get to the trunk to hook it up then crawl back to start it.
    #1 iadss77, Feb 8, 2022
  2. tallprius
    tallprius Member
    62
    29
    texas
    Premium w/ Solar Cells
    I do not think the 12 volt battery actually turns the engine over because the engine is started by the massive traction battery in middle of the car. The 12 volt signals the traction battery to start the car.
    But if car starts when you jump start the 12 volt battery then something is funky with the 12 volt battery or the 12 volt cables. Get a good prius mechanic OR since you are in farm country attach two 12 volt cable attached one to positive one to negative terminal and run them to back seat area BUT this is a bit risky and you could jump start car from back seat. When spring comes problem is solved.
    Also there should be some 12 volt terminals under the hood you can access
    52,863
    you might have a phantom drain overnight. maybe by the time you drive to a place to test it, it has recharged to some extent.
    get a volt meter, and test it in the evening and morning connected to the car, and then disconnected as well, to see if it is draining on it's own.
    what battery, and what is the warranty?
    no, a more powerful battery won't help.
    52,863
    is 20 miles a lot for you? do you normally drive only a few miles day to day?
    that can contribute to low voltage
  5. Mdv55
    Mdv55 Active Member
    246
    181
    Boston
    This.
    OP: Something is killing your 12v overnight. More CCA means nothing to a Prius since the traction battery is what provides the power to "start" the engine. The 12v only boots up and preps a few things.
  6. bisco
    52,863
    reply:
  7. Mendel Leisk
    42,354
    Yeah, either something draining the battery overnight, or a flaky connections? The latter would yield a battery that tests good, but has troubles at start up.
  8. fuzzy1
    10,713
    20 miles / minutes won't add all that much charge. Being hooked up to a battery charger or tender all night should be much better.
    Something else is wrong if hooking up to the under-hood jump point isn't sufficient.
    The 12V also charges the brake accumulator before the car is even started, requiring a burst much more than simply booting up some computers, but still far less than the typical non-hybrid electric starter.
  9. chimiweig
    chimiweig Junior Member
    Chicagoland
    I think it's something like 50A for several seconds so you're right in saying it's much less than non-hybrids.
  10. Mdv55
    Mdv55 Active Member
    246
    181
    Boston
    [QUOTE="fuzzy1, post: 3226685, member: 48224"
    The 12V also charges the brake accumulator before the car is even started, requiring a burst much more than simply booting up some computers, but still far less than the typical non-hybrid electric starter.[/QUOTE]
    Hence the "prep" a few things part of my comment.
    I think there's a chart that someone made floating around that measured the load over time on the 12v system from door open to engine start. I found it interesting.
  11. bisco
    52,863
    quote:
  12. ASRDogman
    ASRDogman Senior Member
    8,067
    4,089
    How old is the battery, 1 year?? Maybe it is defective, in the FROZEN climate, that's hard on a battery.
    If you put it on a charger overnight, 4 amps or less, charge the battery overnight. After disconnecting the
    charger, give it aout 15 minutes to cool off and stablize. Maybe the battery wasn't fully charged when you got it.
    That seems to be a common issue. They sit on the selves for months.
