2014 Prius Plug-in Charging Problem
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by Arnold Trujillo, May 3, 2020.
  1. Arnold Trujillo
    Arnold Trujillo New Member
    Sonora, CA
    2014 Prius Plug-in
    2014 Prius Plug-in does not charge at home on level 1 120 volt charger BUT does charge on public charger. Help!
  2. PA Prius
    PA Prius Active Member
    762
    251
    SE Pennsylvania
    Do you know someone else with any kind of plug-in so you could try your charger on their car?
  3. willyag
    willyag Junior Member
    28
    Orlando, FL
    Several times my charger wouldn't charge my 2012 plugin also. I was very relieved when it worked after I unplugged the charger from the wall for a few hours and then tried again.
    52,775
    welcome!
    1) check the voltage at the wall outlet
    2) try your evse at a known working outlet
    3) press the reset button on the evse
    4) make sure the plug insets all the way into the car, and the button lever locks over the clip
    5) get a new evse
    willyag likes this.
  5. 2013PiP
    2013PiP New Member
    Terre Haute, IN
    2013 Prius Plug-in
    I would say bad charging cord or voltage/amperage problem at the outlet.
  6. Andyprius1
    Andyprius1 Senior Member
    2,327
    859
    Cool CA
    check your home CB, the voltage output on the outlet you are using. If you can charge anywhere away from your home, using your cable, then the car and cable is OK.
  7. Andyprius1
    2,327
    859
    Cool CA
    Replacement cables are pretty cheap now, if you prove it’s the cable, then replace it. You could also take it apart and inspect it. We know the system works on a commercial charging station, so the cars charging is normal.
  8. Andyprius1
    2,327
    859
    Cool CA
  9. Andyprius1
    2,327
    859
    Cool CA
    Bisco, your getting to be our ACE trouble shooter!
  10. jerrymildred
    jerrymildred Senior Member
    11,517
    14,164
    Tampa, FL
    Almost two weeks now. I'm not sure Arnie is actually interested in our answers. :whistle:
    Andyprius1 and bisco like this.
  11. bisco
    52,775
    hit and run :cautious:
    jerrymildred likes this.
  12. Andyprius1
    2,327
    859
    Cool CA
    Could be a Corona hit.
  13. jerrymildred
    11,517
    14,164
    Tampa, FL
    It's possible, I suppose, but highly unlikely. Google shows his county with two cases so far, both recovered. So far, in our county, 0.057% of residents have gotten it (roughly 300 out of 530,000).
    Andyprius1 likes this.
  14. bisco
    52,775
    he meant beer :cool:
  15. Andyprius1
    2,327
    859
    Cool CA
