2014 Prius Plug-in cylinder 1 misfire
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by Adam Guerra, Jun 12, 2020.
  1. Adam Guerra
    Adam Guerra New Member
    Ventura
    Hey everyone, about 9 months ago I bought a used 2014 Prius Plug-in. Recently I started having misfires in the engine. I took it to the dealership and at the time it was only bad spark plugs that weren't changed by the previous owner. Now slightly later I have a check engine light and an even stronger misfire. Again I find myself at my local dealership and they are saying the problem is deeper than just spark plugs, or coil packs. They said it could be something in the cylinder or cylinder head. They are estimating my costs at least at 4 grand. Any ideas what the problem could be and what I could be paying if I took it somewhere else? Thank you.
  2. QuantumFireball
    QuantumFireball Active Member
    420
    269
    Ireland
    Blocked EGR system can lead to serious knocking/pinking, and head gasket failure if it is left long enough.
    Scarface2005 and bisco like this.
  3. Rmay635703
    Rmay635703 Senior Member
    2,705
    1,730
    Somewhere in Wisconsin
    2013 Chevy Volt
    EGR system and cylinder misfiring | PriusChat
    EGR & Intake Manifold Clean Results | PriusChat
    Scarface2005 likes this.
  4. Woodst0ck
    Woodst0ck New Member
    Ventura
    I’m down 5k for the blown head gasket and then some. Get it fixed ASAP or it’s a hugeee repair.
  5. bisco
    52,899
    how many miles on her when she blew?
  6. bisco
    52,899
    how many miles on her?
