2014 Prius Smart Key Proximity Access stopped working
Discussion in 'Prius v Care, Maintenance and Troubleshooting' started by skydivetoday, Dec 22, 2018.
  1. skydivetoday
    skydivetoday Junior Member
    25
    Marco Island , FL
    2014 Prius v wagon
    Hello prius owners,
    I just got my first used prius v and may be missing something. The proximity access worked for a week and then stopped. I have tried the sks button under the dash and the smart key option on in the setup.
    The battery is at 3v and the unlock, lock and engine on/off works fine.
    I have also tried the other fob.
    Any ideas?
  2. skydivetoday
    25
    Marco Island , FL
    2014 Prius v wagon
    Anybody know how Smart Key Proximity Access works or what to check?
    Any links or diagrams?
    52,891
    battery should be 3.3 volts. if that doesn't fix it, test the 12v health
  4. skydivetoday
    25
    Marco Island , FL
    2014 Prius v wagon
    Thanks Bisco,
    Will replace and report- it now makes sense to me except I thought the batt were rated at 3v.
    Later,
    The new battery is 3.1 and no effect on problem. The 12v reads 12.2v standing and charge 14.6v.
  5. bisco
    52,891
    12.2 is low, but it depends on the voltage drop with load. turn the headlights on with car off and watch the voltage drop over a few minutes.
  6. bisco
    52,891
    has any work been done on the car? accidents? are you original owner?
    sks has antennae that pick up the fob signal and proximity sensors.
  7. skydivetoday
    25
    Marco Island , FL
    2014 Prius v wagon
    No work or accident. I bought the car with 33000 mile from first owner after dealership prepurchace check two weeks ago.
    The 12v goes to 11.7 after two minutes of lights on and then starts and runs fine.
    New information: when locked the red light on fob does not start flashing as I walk closer.
  8. skydivetoday
    25
    Marco Island , FL
    2014 Prius v wagon
    Found the Problem!
    I tried techstream and found that the car has three smart key not just my two. I looked under and over everything and found a third smart key stuck under the driver seat. Solved!! I can know go on with my life.
    Thanks for helping me think this out.
  9. Tim Jones
    Tim Jones Senior Member
    1,762
    569
    SE Texas
    2011 Nissan LEAF
  10. Tim Jones
    1,762
    569
    SE Texas
    2011 Nissan LEAF
    Great Post..... Thanks.
