2014 Prius Two : Engine braking?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by everking, Apr 7, 2014.
  1. everking
    everking New Member
    I almost feel like when I release the gas, the Prius is doing some engine braking. Decelerates too quickly (1 mph per second) when driving at around 65 mph.
  2. xpcman
    xpcman Senior Member
    1,302
    295
    California - SF Bay area
    Not engine braking. It's doing electronic braking using the regeneration feature of the transmission.
    Toyota programmed it into the car, just like the "creep" at a full stop, so the car would feel like a "normal" car.
    If you apply a little pressure on the "gas" peddle you can cancel the regen.
    everking likes this.
    52,801
    welcome to priuschat! xpcman has you covered, and the great thing about regeneration is, it's capturing energy that would be lost by a non hybrid vehicle. one big reason why your mpg's are so fabulous! spend some time around here and you'll learn a lot about these unique and wonderful vehicles. all the best!(y)
  4. pmike
    pmike Member
    237
    81
    Central Florida
  5. Seanzky
    Seanzky Member
    150
    28
    NY
    Is it possible you left it in "B" rather than shifting back to "D"? I use "B" a lot when slowing down and only using my brakes when I know "B" won't slow me down to a stop in enough time. But as soon as I come to a full stop, I make sure I'm back in "D" or else acceleration is much slower and whenever I lift my foot off the gas, engine braking takes place.
    I'm also very new to the Prius (only a 5-day old owner) and these are just my observations.
  6. everking
    everking New Member
    Nope. B is very specific to engine braking. You use it on down-hill path to give you extra engine braking. I originally thought that "B" was for "battery" (turned out to be "braking") -- actually thought that I was saving gas on this mode but it's the opposite.
    Thank you! This is the information I needed! It looks like I still have to press the gas very gently to prevent electronic braking. I had been struggling keeping my speed to 65mph on the highway. This explains it. I'll try it out today!
    Thanks pmike!
    Very helpful. I believe I read that somewhere as well but I didn't know exactly know what it meant until your post and xpcman's.
