2014 Prius V loses hybrid charge overnight
Discussion in 'Prius v Main Forum' started by george61, Jun 9, 2019.
  1. george61
    george61 New Member
    florida
    2014 Prius v wagon
    This is what they gave me and said it all looked good.
  2. george61
    george61 New Member
    florida
    2014 Prius v wagon
    DEFINITELY!!
  3. jb in NE
    jb in NE Senior Member
    2,233
    1,599
    Nebraska
    2018 Prius Prime
    You have got to love the service recommendations. Typical dealer up-sell nonsense.
    george61 likes this.
  4. george61
    george61 New Member
    florida
    2014 Prius v wagon
    This is what I'm finding to be true. "no trouble codes means there's nothing to fix"
  5. jb in NE
    2,233
    1,599
    Nebraska
    2018 Prius Prime
    The dealer will not be reimbursed by Toyota for work that is not clearly identified as warranty work. They need to have a clear indication of a failure. This is generally an OBD code or or a failure noted in techstream.
    I had a VW with a failing component covered under warranty. When I read the code my reader reset it. I had to wait for the code to reappear to get it fixed under warranty. This is very typical.
  6. bisco
    52,878
    what i'm asking is; did the service manager look at the number of bars when you dropped it off, and again in the morning?
    and if so, what was his explanation?
  7. jerrymildred
    jerrymildred Senior Member
    11,517
    14,171
    Tampa, FL
    I see that you're in Florida. That's a pretty broad area. Are you in or near Tampa? You might check with Todd at Home - Tampa Hybrids Inc. (@TampaPrius.com). If you're close by, he's a fantastic resource. I can almost guarantee that he can figure it out.
    It does sound to me like the hybrid battery is out of balance. That one snapshot reading of the cell voltages isn't the whole picture. But until it throws a code, it's not a warranty issue, as has been said.
  8. george61
    george61 New Member
    florida
    2014 Prius v wagon
    short answer is no, not to my knowledge. They discounted the idea that having two bars in the morning after sitting overnight is an issue, or that any fluctuation in the bars is an issue, so they just bypassed looking at it. When I took it to another dealership, they didn't keep it overnight, only a couple of hours to run the tests I attached pictures of.
  9. george61
    george61 New Member
    florida
    2014 Prius v wagon
    Right! I understand that once the codes are read they are cleared by default, or can be manually cleared as well. Is that right? So the "stored" codes automatically reset.
  10. jb in NE
    2,233
    1,599
    Nebraska
    2018 Prius Prime
    You can clear all codes including stored codes, but you don't have to clear codes after reading them. My mistake is that I hit the wrong button on the code reader and cleared them. At the dealer, for the case of my exhaust flap problem, the TSB from VW specifically required both a check engine light (which you won't get without an active code) and one of a few codes set.
  11. george61
    george61 New Member
    florida
    2014 Prius v wagon
    New issue: the EV light is now lighting up when I'm up to speeds of 40 mph, and continues to go on and off periodically while I'm up at higher speeds and the Eco mode is still on. It wasn't doing this before and I understand that the car goes into EV automatically when stopped or driving at low speeds or on start-up but is supposed to automatically give over to the ICE when that engages. When this happens the engine starts rumbling like a helicopter. Is this normal behavior? I thought that once it engages the ICE in eco mode the gas engine is running and will only go back to EV when slowed or stopped to save gas. I didn't think they're supposed to run together. Am I wrong about that?
  12. bisco
    52,878
    yes, they can run many ways, independently and in concert
  13. bisco
    52,878
    can you make a recording of the rumbling?
  14. mikefocke
    4,083
    1,864
    Sanford, NC
    I think a drive with a camera recording the dash in movie mode is needed. I'm presuming that there is no history of anything not installed at the factory ever being attached to the car. No relationship strife.
  15. george61
    george61 New Member
    florida
    2014 Prius v wagon
    yes! I did make a recording but it's not that audible in the recording :( .
  16. george61
    george61 New Member
    florida
    2014 Prius v wagon
    I know!! Almost laughable!!! If it weren't so f....ing frustrating!! I've been videoing a lot with one hand on the steering wheel and trying to capture but I really do need a dash mount. The video doesn't pick up enough
  17. rjparker
    rjparker Tu Humilde Sirviente
    11,125
    6,980
    Texas Hill Country
    EV mode is ok at speeds, it just means you are not using the engine at that moment. The rumbling like a helicopter does not sound good. While driving, it normally is almost impossible to hear the engine except under high loads like going up a steep hill or using maximum acceleration. Those conditions cause the cvt transmission to effectively gear down, sort of like shifting to second. You will hear the engine rev up but its clear what its doing.
    The engine and electric motors do have to stay perfectly synchronized to work, if not they will make a racket. If the hv battery still discharges quickly it has a problem. Consider test driving another Prius so you know how it works and sounds. Accelerate hard at speed during the test drive to hear the engine rev up. Other than that, you may have to wait for a code. Just keep an eye on your warranty expiration.
  18. george61
    george61 New Member
    florida
    2014 Prius v wagon
    I wish had driven more of them before I bought! I'll go ahead and test drive more so I can tell the difference. The thing is, when we test drove this one, it was pretty quiet just like I expected it to be, and then within days of having bought it, when the ICE engaged it seemed pretty loud. I hadn't remembered that from another one I'd ridden in a month before, but then the mechanic said it checked out. But it doesnt' do it all the time so that had me wondering. To your knowledge, does it resynchronize on its own? The dealer's warranty has 5 years, 60K miles, but it doesn't cover the hv pack, which has another 3 years manufacturer's warranty. Of course if it isn't showing codes, then they don't fix anything. I don't know if the warranty is worth the $2500 extra I paid for it. What really makes me mad is if the dealership had been upfront, I probably would've sprung the extra 6 or 7 grand and gone new, with a total warranty and all. I've considered trading it back and sucking up the $5K loss to have peace of mind, but not sure if that's worth it either: might get another with its own set of problems
  19. rjparker
    11,125
    6,980
    Texas Hill Country
    First, the factory warranty (better than a dealer warranty in every respect) covers the hybrid system and battery for 8 years and 100,000 miles. That is the warranty to watch. Be sure Toyota has you listed as the owner and recalls, etc are sent to your address. The factory warranty costs nothing extra. Dealer extended warranties are often limited warranties backed by third party insurance companies. They are not worth much.
    Given you have low miles and a few years to go on the 8 year hybrid/battery warranty, I would drive it for awhile and see if it gets better or throws a code. If someone reset the codes when you bought it or perhaps more recently, it may take awhile for it to come up especially if you are just doing highway miles. Stop and go traffic during the summer is the hardest on the battery as it will discharge more completely and will get hotter. On the highway the hv battery will stay charged pretty easily.
    Mendel Leisk and george61 like this.
  20. morre76
    morre76 Junior Member
    25
    IL
    It's like seeing a movie without its end ;).
    How did it ended ?
    My guess is that your hybrid battery was bad and codes were deleted befote you bought the car.
    This can only delete them temporarily.
    In addition I recommend on app named "torque pro" which you can add set of prius pids, and set it to collect logs each x seconds.
    You can select your battery blocks (each is set of 2 cells) voltage and resistance, hv power, 12v voltage and much more.
    Notice that 12v drain battery is a simptom for hybrid pack issue as well.
    I recently recovered my battery pack (replaced 3 cells), while car was parking for almost 2 weeks, new 12v bosch battery drainrd to 5v...
    And keep in mind that your model 2014 has just 5 years warranty, so keep extending it (nit cost much to do it and worth it). If I'm not wrong up to 8 years in total.
