2014 Prius V overheating light on
Discussion in 'Prius v Care, Maintenance and Troubleshooting' started by Ogonzalez, Aug 5, 2025.
  1. Ogonzalez
    Ogonzalez New Member
    I have a 2014 Prius V wagon with this issue....
    When I drive to work in the morning at 4am in Los Angeles, the red temp light turns on for about 10 seconds then turns off. I do about 10 minutes of street driving then hit the fwy and at about 65-70 mph after the light turns on. What I started to do is turn on the heat to full blast in the cabin as soon as I turn the car on to leave the house. If the heat kicks in before I hit the fwy, the light doesn't turn on (I can start to feel the hot air and it has an odor). If I turn the heat on full blast and it doesn't kick in by the time I get on the fwy, the light turns on until I feel the heat start to kick in, then the red light goes away. I can drive the rest of the day and the light will not come on, even with fwy driving. This happens just in the morning. Has anyone had this issue? Is the thermostat stuck? water pump? or possibly the radiator fan? I'm a DIY inexperienced mechanic that can do the basic maintenance but learning to do more. I appreciate any help.
    52,861
    how many miles on her? check for trouble codes with a prius aware scanner
  3. rjparker
    rjparker Tu Humilde Sirviente
    11,116
    6,974
    Texas Hill Country
    You're playing Russian Roulette with your engine. I and many others would pull over safely and tow it to a shop or home.
    Adding coolant yet?
    Any head gasket leak stop added?
    Odds are good it's a water pump which often fail gradually. It could be a head gasket leak adding gasses into the coolant while burning some coolant. This is generally preceded by rough rattling cold starts until it's really bad when it will shudder and rattle after a traffic light.
    Head gasket sealant has been known to partially clog the micro channel radiator.
    An outside and rare chance is a stuck open exhaust heat recirculation valve. Or an equally rare bad thermostat.
    We will assume it is high miles which makes the water pump or head gasket likely.
    Monitoring the engine temperature in early controlled conditions is diagnostic.
    Finally, don't buy an aftermarket water pump. Your engine will suffer further and your car's reliability will continue to fall.
    #3 rjparker, Aug 6, 2025
    Brian1954 and BiomedO1 like this.
  4. BiomedO1
    BiomedO1 Senior Member
    4,616
    2,416
    Left Coast
    The red temperature lamp turns ON around 245F, just because it's not ON does NOT mean it isn't doing damage to your engine. Just that your below the 245F threshold. Normal operating temperature for that car is 185F-205F. All that plastic under your hood is suffering and will likely start warping, creating another set of future problems.
  5. 2015V-BadHG
    2015V-BadHG Junior Member
    26
    Portsmouth NH
    2015 Prius v wagon
    Yup, my 2015 did the same until I changed the HG.
    You may just need a water pump and thermostat. BUT more likely whats happening is due to the HG leak into cylinders you now have air in your cooling system. IF there is enough coolant at the water pump it will flow but once it pushed that thru and coolant is too low at the pump car over heats.
    Unfortunately that RED light comes on way too late. You have likely already at least blown HG, maybe even warped the head.
    Keep using it and you can even bend the piston rods and engine is pretty much toast.
    BiomedO1 likes this.
  6. Xterra72
    Xterra72 Senior Member
    1,437
    1,684
    This is what happened to me.
    The engine water pump is going out. If you keep driving without replacing the engine water pump, you will have the head gasket problem.
    Replace the water pump as soon as possible before the head gasket goes out.
    My experience.
    Brian1954 likes this.
  7. Mendel Leisk
    42,352
    Another one-n-done?
