2014 Prius V Wagon Rotten Linkage Please Help
Discussion in 'Prius v Care, Maintenance and Troubleshooting' started by Danny9992024, Jul 9, 2024.
  1. Danny9992024
    Danny9992024 New Member
    CT
    2014 Prius v wagon
    Good morning, everyone. I am new to this Priuschat. I just bought a 2014 Prius V wagon, and it has a rotten linkage right beneath the exhaust gasket due to water leaking out from the exhaust gasket joint for a long time, I believe. I would like to know if I need to replace this rotten linkage. I already replaced my exhaust gasket, so no more water is sipping out. And can someone please tell me the part number of the linkage, and if I don’t replace it, will I still be safe on the road? And what is the purpose of this linkage? Please see my first two photos from my Prius V wagon. The 3rd and 4th photos are from online, and I circled the linkage that I am referring to. If anyone has replaced it, is there a torque or procedure manual or diagram for it? If anyone has repaired it, any suggestions or video that I can watch? Any help would be greatly appreciated. Thanks
  2. vvillovv
    vvillovv Senior Member
    4,337
    1,519
    NY
    I'd recommend you check the Brackets that bar connects to on both sides. Than make sure you can break loose the bolts that hold the bar to the brackets. Than check these parts to see if they match what you've looked at while working on the car.
    This part fits the vehicle you selected:
    My Vehicle: 2014 Toyota Prius V United States Of America; ZVW41L-AXXEBA
    53605-47020 Genuine Toyota Brace Sub-Assembly, Rear S
    Toyota 53605-47020 Brace Sub-Assembly, Rear S
    the part # for the Bracket and the Bar is above
    the part # for the Bar and the bushings see below
    Toyota 53605-47021 Brace Sub-Assembly, Rear S
    53605-47021 Genuine Toyota Brace Sub-Assembly, Rear S
    bisco, Danny9992024 and Air_Boss like this.
  3. Air_Boss
    Air_Boss Senior Member
    4,259
    1,197
    New Yawk
    That brace must have been physically compromised for it to be consumed like that. Is the rust bad all over the undercarriage?
  4. Danny9992024
    CT
    2014 Prius v wagon
    See my photos. I suspect the bar got rotten due to water continuously came out between exhaust gasket but that has been replaced. Can you tell me the purpose of this sub link bar? Don’t think it will break but if it does, any safety concern? The main frame black one behind has no rust. Thanks
  5. Mendel Leisk
    42,355
    Looks to be; the rear jacking point rust looks pretty advanced.
    Air_Boss likes this.
  6. Danny9992024
    CT
    2014 Prius v wagon
    yes and I won’t use that rear Jack point to Jack up this prius ever for safety reason. Just wondering if prius v has left and right side Jack point? Or just front and back? The front one is rust free.
  7. Mendel Leisk
    42,355
    The rear axle looks nearly rust-free, which is odd. Maybe replacement?
    Not sure what you could use instead of the rear jacking point. Maybe the solid rear axle. Go cautiously though. Maybe put a channel section under, spread the load.
    South Main Auto guy (YouTube mechanic in upstate New York) has seen it all, uses phrases like "10 years around here and they're ready to be crushed". He orders salvage suspension parts from a wrecker in Florida, lol.
    I've used boiled linseed oil as a rust arrester, might help, but some of that is advanced.
    #7 Mendel Leisk, Jul 10, 2024
  8. Mendel Leisk
    42,355
    Our west coast BC, Canada, 1010 Prius. Low kms, garage-stored, and being retired we have the luxury of just staying off the roads when it's snowed and the municipality has turned the roads into salt licks. Plus multiple applications of boiled linseed oil:
    The not exactly hidden cost of road salt. It's all washing into local streams too. :mad:
    vvillovv likes this.
  9. vvillovv
    4,337
    1,519
    NY
    The parts are also called the
    Rear Suspension Brace Sub-Assembly
    there would be more information about the parts and installation instructions in the repair manual.
    #9 vvillovv, Jul 10, 2024
    Danny9992024 likes this.
  10. bisco
    52,863
    we've forgotten how to drive in inclement conditions
  11. Air_Boss
    4,259
    1,197
    New Yawk
    Leave the fun to those who can!
  12. Mendel Leisk
    42,355
    Attached is gen 3 (hopefully similar) info:
  13. tphagger
    tphagger Junior Member
    Poughquag, NY
    I have the exact same problem. Mine is rusted through on the bottom on one side and appears to have bowed upwards slightly, causing the exhaust flange to knock against it at highway speeds (I think). Started happening after I did the brakes and tire rotation, I think lifting by the rear jack point caused it to flex and bend upward just a bit. Both of the rear exhaust brackets snapped off as well, have those somewhat fixed - the exhaust is original and looks fine otherwise.
    Fair amount of rust under there, live in the Hudson valley region in NY, so definitely salted roads territory, but not nearly as bad as my 1997 Camry, which was rusting away when I sold it in 2008 or so.
    No one answered what this thing does, but I'm guessing it's just a frame stiffener. I need to go see if I can get the bolts out before ordering the part. Have a piece of flex pvc over the touch point right now to test if that is really what is causing the noise.
