2014 prius V5 30mpg
Discussion in 'Prius v Technical Discussion' started by Sony, Apr 5, 2018.
  1. Sony
    Sony New Member
    Us
    2014 Prius v wagon
    I recently buy 2014 prius v5 with28k miles. I drove her about 1600 miles. I usally drive city by my self 160 pound, tire pressure 40 on all tires. I use pulse and glide techneqe and still getting 30 mpg.. there is no recall on this modal dealer did reprogramed before sale. I changed engine filter, cleaned ev fan and vent but no gain... last drive with full tank 350 miles with 11 gallon fillup.
    52,740
    welcome!
    hmmm, that's a tough one. do you have the history of the car? might it have been in an accident?
    tell s about your driving conditions and hvac use.
  3. Bingee
    Bingee Member
    210
    62
    Michigan
    Where do you live , what has the temperature been ,, mpg drops in the cold weather
  4. rjparker
    rjparker Tu Humilde Sirviente
    10,940
    6,861
    Texas Hill Country
    These cars can get 36 mpg at 85 mph and certainly the epa 41/42 mpg at normal speeds. I might look at the brakes and see if they are dragging. Check the air filter and make sure it's not clogged. Maybe a clogged catalytic converter but I would think you would get a check engine. I assume no lights are on indicating some engine codes.
    Compare Original and New Fuel Economy Estimates
  5. fuzzy1
    10,687
    jerrymildred likes this.
  6. mikefocke
    4,071
    1,856
    Sanford, NC
    1. Compute your MPG by hand, not using the car's computer display. More accurate across multiple tanks.
    2. Set the display to instantaneous readouts of MPG and observe. In what circumstances does the readout seem low? Up hills, down hills, accelerating, at constant speed? What is the speed that seems to display 42 MPG?
    3. Where are you located? What sort of trips? Long cruises? Short? Hot? Cold?
    Lets see if we can get any clues.
    Aaron Vitolins likes this.
  7. Sony
    Sony New Member
    Us
    2014 Prius v wagon
    Car has clean one owner no accident no rental no recall history by carfax.
  8. Sony
    Sony New Member
    Us
    2014 Prius v wagon
    Well i manually collect the mpg and it matched with computer reading. I live in seattle area. There is no check engine light brakes are well working no dragging at all, my friend have v3 2015 in same area driven and his computer avg mpg is always more then 42.. but one thing i noticed my car is faster then other v i driven....
  9. Rob43
    Rob43 Senior Member
    1,373
    1,050
    VA, BMW Race Car, BMW R1200R, BMW 330Ci, Ford F350
    2013 Prius v wagon
    If you exhaust all the good ideas that the above forum members listed, pull your spark plugs & do a compression test
    on your motor.
    Rob43
  10. Prodigyplace
    12,709
    11,847
    Central Virginia
    For comparison, my son has a 2015 Prius v 5 and says he averages 42 mpg US in the foothills of the Blue Ridge Mountains.
    Is that a typo or does the car only have 28K miles? That is extremely low!
  11. bisco
    52,740
    what brand and model tires?
    do you drive her hard and put her up wet?
  12. Prodigyplace
    12,709
    11,847
    Central Virginia
    The larger question is what model dryer does @bisco recommend?o_O
    Or, what alternative car for rain or snow? ;):whistle:
  13. Tim Jones
    Tim Jones Senior Member
    1,760
    567
    SE Texas
    2011 Nissan LEAF
    I'm getting 42 / 44 most of the time and I have well over 250,000
  14. RAM v
    RAM v Junior Member
    72
    St. Paul, MN
    2014 Prius v wagon
    My 2013 V with almost 70K miles has lifetime average of over 47 (actual fill-up calculated) MPG. The only time mine falls below 40 MPG is during near or sub zero F temperatures during the (Minnesota) winter. With warmer 50-60F spring temps right now I'm getting over 50MPG.
  15. Tim Jones
    1,760
    567
    SE Texas
    2011 Nissan LEAF
    U have a picture of that?
  16. Tim Jones
    1,760
    567
    SE Texas
    2011 Nissan LEAF
    Might depend what inverter firmware the cars have. Just got mine back from 3rd update my mileage is down.
  17. Prodigyplace
    12,709
    11,847
    Central Virginia
    According to your profile you must have the only AWD-e Prius v in existence. I do not think Toyota had even invented that in 2013.
    My son’s Prius v has never had any firmware updates that I remember. He only gets that if due to a recall.
  18. Tim Jones
    1,760
    567
    SE Texas
    2011 Nissan LEAF
    I don't know what year his prius is but there have been three to try and protect the inverter that will blow.
    When the inverter blows they might get a bit tense without the updates.
    Have him run his vin through the toyota site.
  19. Prodigyplace
    12,709
    11,847
    Central Virginia
    It is a 2015 Prius v.
  20. RAM v
    RAM v Junior Member
    72
    St. Paul, MN
    2014 Prius v wagon
    What do you want a picture of? My Fuelly icon is accurate and I have entered every fill-up since I bought the car in Jan 2015.
    Prodigyplace likes this.
