2014 Prius won’t shift into gear
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Josh Cottrell, Feb 22, 2021.
  1. Josh Cottrell
    Josh Cottrell New Member
    Utah
    Hey! Hope I’m posting in the right place. As of today, my Prius refuses to shift gears. Basically what happens when I try to turn on the car is that the dashboard turns on and all the indicator lights stay on (oddly enough the media console doesn’t turn on, though). If I try to shift it into any gear, I just get two short beeps.
    The key fob works, as I can use it to lock/unlock the car as normal. I’ve also heard that it could be a brake sensor not being able to tell if I’m holding the brake while turning the car on, but I don’t think that’s the case, as the light on the car’s power button turns from orange to green while I’m pressing the brake down. However, once I take my foot off the brake, the light just turns orange again.
    Any help or troubleshooting suggestions would be much appreciated! I’ve never had any problems with the car since I got it in 2016, and it showed no indication of malfunctioning prior to this.
  2. tankyuong
    tankyuong Senior Member
    1,555
    662
    Central MO
    Check the 12v battery voltage
  3. ChapmanF
    19,041
    Does the word READY appear on the dash?
