2014 Source Selection of Plug-In Hybrid
Discussion in 'Other Cars' started by bwilson4web, Jul 13, 2016.
  1. bwilson4web
    16,547
    Source selection is a formal engineering process that compares different products against the requirements to identify the best candidates. Now I had already decided to go with a used 2014 for price which every candidate car meets. The only question remaining, requirements and capability.
    For requirements, I used two families. The first is our older, two adults, no kids, with "stuff." The second a younger family with kids. With different requirements, their logical choices will vary.
    For the capabilities, we used EPA and automotive reviews:
    metric\2014 BMW i3-REx Accord plug-in Chevy Volt Prius plug-in
    1 MPGe 117 115 98 95
    2 seat belts 4 5 4 5
    3 volume 99 112 108 116
    4 0-60 mph 7 7.7 8.7 10.2
    5 range 150 570 380 540
    6 MPG 39 46 37 50
    Since some metrics are better with low number and others with high numbers, we decided to use a linear scale, 1-worst and 4-best. A linear function is not always the best but good enough for our purposes:
    metric\score 4_best BMW i3-REx Accord plug-in Chevy Volt Prius plug-in
    1 MPGe 4 3 2 1
    2 seat belts 1 2 1 2
    3 volume 1 3 2 4
    4 0-60 mph 4 3 2 1
    5 range 1 4 2 3
    6 MPG 2 3 1 4
    So the BMW i3-REx has the highest MPG3 and gets a "4". In contrast, the Prius plug-in has the worst MPGe and gets a "1". Of course a linear scale may not reflect true worth but that is beyond the scope of this example.
    Having assigned objective quanties, 1 to 4, for each metric, we need to use the requirements weighting for each family. A non-linear percentage of merit is assigned to each metric. This is multiplied times the weight value to make a 'suitable for use' number. These are added up so the car with the highest number is the one best suited for that family. In this case, the empty nesters.
    1 Adults 2 + trailer 3.30 3.13 1.93 1.56
    2 MPGe (55%) 2.20 1.65 1.10 0.55
    3 seat belts (2%) 0.02 0.04 0.02 0.04
    4 volume (3%) 0.03 0.09 0.06 0.12
    5 0-60 mph (20%) 0.80 0.60 0.40 0.20
    6 range (15%) 0.15 0.60 0.30 0.45
    7 MPG (5%) 0.10 0.15 0.05 0.20
    So by score, the "BMW i3-REx" is the best for this family followed by Accord plug-in, Chevy Volt, and Prius plug-in.
    Doing the same analysis for the family of two and three kids:
    1 Adults 2 + kids 3 1.59 2.47 1.40 2.34
    2 MPGe (15.0%) 0.60 0.45 0.30 0.15
    3 seat belts (55.0%) 0.55 1.10 0.55 1.10
    4 volume (20.0%) 0.20 0.60 0.40 0.80
    5 0-60 mph (3.0%) 0.12 0.09 0.06 0.03
    6 range (2.0%) 0.02 0.08 0.04 0.06
    7 MPG (5.0%) 0.10 0.15 0.05 0.20
    The Accord plug-in followed by the Prius plug-in are the leading candidates. The BMW i3-REx and Chevy Volt both trail badly because of the four seat belts meaning it could never carry everyone for a trip. In fact, the 4-seaters would have been eliminated as having 5-seats is a mandatory requirement. But I included them only for illustration of the approach.
    Having spent tens of thousands of dollars on a ride tends to make one a 'fan boy' and sometimes they don't realize other families have different requirements. So this leads to endless bickering over which ride is best. Engineering doesn't care because it is requirements driven and hang the rest.
    #1 bwilson4web, Jul 13, 2016
  2. Trollbait
    12,832
    I think you have a typo for the Volt range.
    "Having spent tens of thousands of dollars on a ride tends to make one a 'fan boy' and sometimes they don't realize other families have different requirements."
    Having been swimming since a young child, it was actually decades before in sunk in that others couldn't swim as well as I could.
  3. bwilson4web
    16,547
    With the exception of 0-60 seconds, I used the EPA numbers including range for the 2014 models. My eyes see 380 miles for that model year. What were you expecting?
    #3 bwilson4web, Jul 13, 2016
  4. Trollbait
    12,832
    You graded it 4 for range while it has neither the best total range nor electric range. Were you judging range by some other metric?
    bwilson4web likes this.
  5. bisco
    52,877
    that was the first thing i noticed as well. should be 1,4,2,3 from left to right?
  6. bwilson4web
    16,547
    Old man eyes. I'll fix tonight. It is in a spreadsheet and manual data entry ... 'bout as good as my speellin. It is supposed to be total range.
    I did not give high weighting for range so probably won't shift the order much. Now if someone were a sales critter or field service tech, it would have a higher ranking and a Level 2 ECO might be a better solution.
    #6 bwilson4web, Jul 13, 2016
  7. bisco
    52,877
    now we need a list of all possible metrics for users to plug in.
