2014 three nav sd card location ?
Discussion in 'Gen 3 Prius Audio and Electronics' started by messenger, Aug 13, 2020.
  1. messenger
    messenger Junior Member
    30
    Fairfield, IA USA
    My wife just bought a 2014 three with Entune and navigation, the nav map is from 2013 and I'd like to get a later map but I can't find where the micro sd card slot is located. I looked in the owners manual under navigation and it said, "see the Entune manual" the Entune manual said, "see the owners manual". I know the card and slot are tiny but after looking everywhere I could think of no luck. If anyone knows the location for the card slot and could let me know it would be great.
    Thanks,
    Tim
  2. Grit
    Grit Senior Member
    6,577
    4,231
    Wilkes Land
    A micro sd slot in a gen 3? How come no one ever revealed this info?
    52,823
    is there a dvd under the drivers seat?
  4. messenger
    30
    Fairfield, IA USA
    No dvd under the seat, I think I know where this is going: no nav sd card this is a dvd update only? I was thinking by 2014 they had moved to the sd card.
  5. Attila Fekete
    Attila Fekete Member
    164
    59
    Budapest, Hungary
    What is the head unit model number - usually at the bottom of front of the HU?
    #5 Attila Fekete, Aug 14, 2020
  6. bisco
    52,823
    different years and packages might have different h/u's. try asking a dealer parts department
  7. messenger
    30
    Fairfield, IA USA
    The unit number on the face plate is 57032
  8. NewHybridOwner
    NewHybridOwner Active Member
    607
    283
    W. Michigan
    What I found was that maps on my 2015 Prius FOUR could be updated (at excessive cost, so I haven't done it: I use the navigation apps on my phone) using a gizmo plugged into the USB slot in the center console. It has to be done by the dealer and involves the use of a vehicle-specific activation code. From memory, it's likely to cost $300 at least, including labor.
  9. Attila Fekete
    164
    59
    Budapest, Hungary
    As mentioned above, this HU has internal flash to store the map. It can be updated by using usb stick with the update files. As far as I know there is no other way than using the Toyota tool to create the files on that usb stick.
    (So it has no SD slot.)
  10. NewHybridOwner
    607
    283
    W. Michigan
    And by "vehicle-specific activation code" I mean specific to the VIN or to the Serial No. of the head unit.
  11. bisco
    52,823
    yeah, anyway. not much you can do without a $$$dealer$$$
  12. Grit
    Grit Senior Member
    6,577
    4,231
    Wilkes Land
    At times When I’m frustrated & stuck in road construction zones, I wish I can reach down for a dvd, pop it and watch a movie.
  13. bisco
    52,823
    with the right set up, you can
  14. Grit
    Grit Senior Member
    6,577
    4,231
    Wilkes Land
    My “smartphone” is from 2015, it can only playback 720p. That’s max resolution for dvd video quality playback :ROFLMAO:
