2015 1.8L rattling at low rpm, head gasket?
Discussion in 'Gen 3 Prius Main Forum' started by stokesey, Oct 19, 2024.
  1. stokesey
    stokesey Junior Member
    62
    Southern Cal
    GPT for the win. It all makes sense, but again I doubt a clogged EGR is the root cause of blown heads. If your rings are leaky, that's 100x worse than poor exhaust gas recirculation.
    Other causes of blown heads are things like:
    * not changing your oil
    * water pump failure
    * coolant loss and overheat(most common cause)
    * cracked radiator (see coolant loss)
    * bad gasket design (Subaru)
    * blocked water jackets
    I'd put most of those ahead of EGR blockage.
    Blocked EGRs mostly cause poor engine performance in my experience.
  2. stokesey
    62
    Southern Cal
    Probably a good thing I was skeptical of that great advice in hindsight tho, right? I could be out there swearing into the gloom and breaking off head bolts...
  3. Eddie25
    Eddie25 Active Member
    496
    209
    MI
    It's been what... 24 hours? I usually consider "hindsight" as a longer time frame than that, but you do you.
  4. stokesey
    62
    Southern Cal
    Good advice thanks.
    Conpression was 120psi across all 4 cylinders. Did the test dry and didn't bother with wet test because I think its within spec. Also all 4 are the same which implies roughly even wear.
    Coolant hasn't dropped and I don't see any obvious leaks.
    When you say run a DTC do you mean a Toyota Techstream test sequence? I have a generic bidirectional scan tool, but so far Prius support hasn't been the best in my limited experience.
    Spark plugs and coils were replaced and all the permanent OBD codes vanished pretty quickly. The engine hasn't rattled a bit since I did the fixes. Also cleaned most of the intake passages and EGR. That reminds me let me check the resistance of my old coils...
  5. stokesey
    62
    Southern Cal
    Ahh so you're still waiting for the "I told you so" about the cheapo coils and plugs? You can have it in a year, but by that time I'll have salvaged like 12 OEM coils from a junkyard. Let me know if you need a set.
  6. Eddie25
    496
    209
    MI
    No, more so that you might experience more cold start rattles soon. Something tells me you wouldn't be back here to tell us about it, but I hope you got it fixed.
    rjparker likes this.
  7. stokesey
    62
    Southern Cal
    No, I'll be back for sure so rjparker can tell me I've got a blown head again and make his dumb joke again
  8. stokesey
    62
    Southern Cal
  9. Melthias
    Melthias Member
    99
    36
    Southern Maine
    Can you post pictures of the cylinders? Were you able to examine the walls for coolant? What was the result of the paper test? I would be worried by the green fluid in the test kit. I hope you are right that the plugs and the coils fixed the problem. Please do report back in a few months to confirm that is all that it was.
  10. stokesey
    62
    Southern Cal
    I can't rule out multiple issues with this engine as it has high miles but the compression reading is good. Here are the cylinder pix. Borescope is pretty poor quality but you can see some distinct differences.
    Cylinder 1:
    Cylinder 2: Cylinder_2.png
    Cylinder 3:
    Cylinder 4:
    Notes: the metal shavings in Cylinder 2 might have blown or fallen in while I was pulling the plugs and coils. I blew them out by cranking briefly with no plugs or coils. The carbon in cylinder 3 is very different from the other bores. Could be the source of the problem from clogged up intake passages? Or that coil or plug might've been weak/fouled. The plugs all looked roughly equally worn tho. Resistance on all the coils was 0.32 Kπ.
    The car has driven well for 400 miles now with no issues at mixed city/highway speeds. Only complaint would be low power but I drove a faster car before owning this. Also I'm adjusting to the drive by wire throttle so I'm hesitant to put the pedal to the metal too much. Also I suspect the hybrid battery is getting a little long in the tooth.
    Thanks for any input
  11. stokesey
    62
    Southern Cal
    Also note that I didn't move each piston to BDC so 2/3 were probably down while 1/4 are likely up (or whatever the firing order would dictate)
