2015 engine, let 12v battery die, first start rough - is this normal?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by MrPete, Nov 8, 2023.
  1. MrPete
    MrPete Active Member
    507
    194
    Colorado, USA
    I've been working on my 2011 Prius, that has a new 2015 engine.
    Was doing body work etc... in retrospect I'm not too surprised the 12v battery died -- I did nothing to keep it trickle charged :(
    Everything is now reassembled, and I charged the battery. I did have to clear codes, because I forgot to connect the ground wire to the HV battery case. (That's another "Check Hybrid Battery" warning signal, besides the infamous failure-to-completely-seat the interlock.)
    On first start, the engine ran VERY rough, then settled down after about 15 seconds before shutting down since I'm not actually going anywhere.
    My question, based on a vague memory: if the 12v battery dies, by any chance do the ECUs forget their memory of engine parameters, so the engine may run rough for some amount of time?
    If so, is there anything I can/should do to get past this rough patch quickly and/or properly?
  2. ChapmanF
    18,947
    Yes, that's exactly what happens; various ECUs can lose various saved values, but in particular, the ECM loses its "ISC learning" (idle speed control) value. The "ISC learning" procedure in the manual is not much different from what you did. If you want to be fastidious about it, you first clear any DTCs, put the car in inspection mode, with all accessories turned off, and start the engine and let it warm up without touching the go pedal at all, and it should have stopped running weird by then. But it's not as if it won't eventually learn the right value anyway, even if you aren't following those steps exactly.
    If it shut down quickly (because you weren't going anywhere) instead of fully warming up (because you weren't in inspection mode to keep it running), you might want to go back and give it that chance to fully warm up. The smoothing out just before it stopped might not mean the ISC learning was done, but just that it shed the load of battery charging for those few seconds before shutting down.
    If you start it up in inspection mode and it is still disturbingly rough while charging, you might shift to N while it's warming up, to take that extra load off of it until the learning is complete.
    If you have Techstream or another scan tool that can show the ECM data list, you can look at the "ISC learning" (Compl or Incmpl) to see whether it thinks it has completed the learning yet or not.
    #2 ChapmanF, Nov 8, 2023
    MrPete likes this.
  3. Mendel Leisk
    42,250
    Whenever I've had the battery disconnected (and no memory saver attached), during the next few start-ups there'll be an unusual revving up, for about 3~5 seconds. Pretty smooth though.
    MrPete likes this.
  4. MrPete
    507
    194
    Colorado, USA
    Thanks! All is well now :)
