2015 Engine Revving When off of accelerator pedal
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by wilsonsk, Nov 13, 2019.
  1. wilsonsk
    wilsonsk Junior Member
    32
    I have a 2015 Prius with 81,000 miles on it. A week ago the engine started revving up to around 3,000 RPMs when I took my foot off of the accelerator and let it coast. The engine is not powering the car, just turning free as if in neutral. If I tap the accelerator pedal it slows down but usually speeds back up again. It also will do this at stop lights as well. It doesn't do it all of the time, probably 70% of the time. Drive-ability seems to be pretty normal, fuel economy also seems pretty normal. It seems like it does it more when the engine is relatively cold, not fully warmed up, and does it less when fully warmed but it still does it. It never applies power to the wheels when it does it nor does it indicate that it is charging the battery.
    Thoughts?
  2. JC91006
    16,936
    8,647
    How did you determine it to be 3000 rpm?
    Grit likes this.
  3. wilsonsk
    32
  4. wilsonsk
    32
  5. wilsonsk
    32
  6. bisco
    52,837
    sounds like something is dirty. air filter, throttle body, etc
    dig4dirt likes this.
  7. PriusGuy32
    1,417
    514
    Harrison Township, Michigan
    Grit and dig4dirt like this.
  8. Grit
    Grit Senior Member
    6,577
    4,231
    Wilkes Land
    Attila Fekete, mikey_t and PriusGuy32 like this.
  9. wilsonsk
    32
    I read that and 2 others, no definitive answer and symptoms not all the same, hoped someone had some new info, my impression of the purpose of a forum, sorry if I misunderstood
  10. dig4dirt
    dig4dirt MoonGlow
    1,153
    741
    Lancaster Co PA
    ouchee wawa
    I wonder where @Grit gets his signature lines :whistle:
    PriusGuy32 and bisco like this.
  11. bisco
    52,837
    i'm just sad that i haven't written anything quote worthy :unsure:
  12. dig4dirt
    dig4dirt MoonGlow
    1,153
    741
    Lancaster Co PA
    How long have you have this Prius for?
    How old is the 12v battery?
    What are the temps in your location?
    The Prius "c" has been known to do this kinda thing too.
    I have experienced it many times, only in cold weather....however never xp'd it in the Gen3
  13. Raytheeagle
    Raytheeagle Senior Member
    11,269
    15,528
    Bay Area, California
    2019 Prius Prime
    Is the gas cap tight?
  14. TMR-JWAP
    TMR-JWAP Senior Member
    6,404
    6,095
    Columbia, SC
    Hmmm......gross leak. Wonder if the lean condition is a big vacuum leak
    Mendel Leisk and Raytheeagle like this.
  15. wilsonsk
    32
    I bought it 2 years ago with 12,000 miles
    Original 12v battery
    Unseasonably cold this year and it did seem to start with cooler weather. We've had a couple below-zero mornings already.
  16. fotomoto
    fotomoto Senior Member
    5,639
    3,815
    So. Texas
    Didn't read the other thread but has your driving changed? More hills or need to regen with a full(er) battery? Is the HV battery full when this occurs?
    Using more heat now?
  17. PriusGuy32
    1,417
    514
    No longer interested in assisting. All the best!
  18. Raytheeagle
    11,269
    15,528
    2019 Prius Prime
    You’d think with over 83k posts you’d have said something to remember :p.
    dig4dirt, bisco and PriusGuy32 like this.
  19. Mendel Leisk
    42,332
    Try "the peeing in cereal" line?
    This gizmo seems to be "in the news" a lot, hoses blowing off, which would make for a gross vacuum leak:
    VACUUM PIPING. 2010 Toyota Prius Hatchback HYBRID | Toyota
    Specific part:
    2010 Toyota Prius Hatchback HYBRID Valve assembly, vacuum switching. Engine - 2586037020 - Genuine Toyota Part
    Someone here (can't find at the moment) had one go bad, replaced it and problem went away.
    In the (attached) Repair Manual excerpt it's referred to as "purge valve".
    p/n: 25860-37020
    #19 Mendel Leisk, Nov 15, 2019
    dig4dirt and bisco like this.
  20. Grit
    Grit Senior Member
    6,577
    4,231
    Wilkes Land
    I believe it went something like “Sorry to pee in your cornflakes but...” And it did make my signature quotes.
