2015 (Gen3) Prius Two - Homelink Mirror Wiring?
Discussion in 'Gen 3 Prius Accessories and Modifications' started by 15SuperPrius, Apr 3, 2020.
  1. 15SuperPrius
    15SuperPrius Member
    128
    49
    FL
    Hi folks,
    Does anyone know if the base car (Prius Two) comes prewired/with a harness to install a Homelink mirror from another Gen3 Prius? Or has anyone tackled this project successfully?
    Thanks!
  2. TNToy
    TNToy New Member
    23
    22
    Memphis TN
    I’ve installed one in mine.
    It’s rather easy actually. There’s a connector in the driver’s kick panel with both an ignition hot and battery constant wire which I piggybacked off of. Given the low current draw of the device, I wasn’t worried about overloading an existing circuit.
    On a 2011 prius, this black connector in the kickpanel had constant hot (red) and ignition hot (blue)
    15SuperPrius likes this.
  3. 15SuperPrius
    15SuperPrius Member
    128
    49
    FL
    Cool, thanks! Question, would it not be easier/possible to draw power from the dome lights, which are closer to the mirror? How’d you go about routing the wires from the kick panel?
  4. Grit
    Grit Senior Member
    3,430
    2,809
    NorCal (Non Bay Area)
    :LOL:
  5. TNToy
    TNToy New Member
    23
    22
    Memphis TN
    I forget which ones is lacking in the dome assembly, but you need both ignition hot and a wire that’s 12+ at all times.
    Pull the door weatherstripping next to the dash, and pop the A-pillar trim loose. Tuck your wire up over the edge of the headliner across the top of the windshield. Then route it behind the airbag in the A-pillar down into the kick panel.
  6. 15SuperPrius
    15SuperPrius Member
    128
    49
    FL
    Not sure what’s funny - many cars come prewired since a Homelink/autodim mirror is often optional, and this is where the prewired harness would be found.
  7. 15SuperPrius
    15SuperPrius Member
    128
    49
    FL
    Thanks for the info! (y)
  8. TNToy
    TNToy New Member
    23
    22
    Memphis TN
    Sure! This is literally a 15 minute install. Half an hour if you take your time.
  9. Serenity
    Serenity New Member
    23
    San Antonio
    Those of you who have done this successfully, could you point me to the mirror you used please?
  10. drowssap
    drowssap Member
    154
    30
    Any mirror will work. There are only two wires to be connected for the base mirror with homelink but more if you purchase a mirror with a small LCD screen for backup cam image.
    Serenity likes this.
  11. TNToy
    TNToy New Member
    23
    22
    Memphis TN
    The color on this one (compass comes in different colors) matches a prius’s blue-green interior. Looks 100% factory, and opens your garage. And the auto-dimming works flawlessly. Which you’d expect: these are a factory offering in Tacomas, Avalons, Lexus’s, etc.
    I like one subtle security feature: your ignition has to be on in order to power up the mirror. So no one can break into your car and use the garage door opener to gain access to your home.
    Gentex 453 Auto Dimming Homelink With Blue Hidden Compass | eBay
    Once you install it, look up “homelink mirror reset” on Youtube and then “homelink mirror compass calibration” and “homelink mirror programming.”
Loading...
