2015 Maintenance Required Message reset
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Patrick Wong, Dec 28, 2018.
  1. Patrick Wong
    18,210
    6,517
    My 2015 has logged 20K miles. The Maintenance Required message appears in the dashboard display. After changing the engine oil and filter, I tried to reset the message, but it refuses to reset.
    My procedure:
    1. Set Trip A counter to display, make car IG-OFF.
    2. Hold Miles/KM button down, depress POWER button two times.
    The message refuses to reset. I've reset this message a few times during my ownership (since new) of this car, so what am I missing now?
    Thanks!
  2. Bay Stater
    Bay Stater Senior Member
    534
    771
    Central Mass
    I start with the ignition off. While pushing down the miles/km button, press the ignition on button once to initiate the maintenance reset. A bar indicating the reset is in progress should appear. When the bar completes, the reset is done. Hopefully this works for you. ;)
    Patrick Wong likes this.
  3. Patrick Wong
    18,210
    6,517
    If I press the POWER button only once, I just get a message saying to depress the brake pedal to start the car.
    Bay Stater likes this.
    52,683
    i wish i could help, but i have struggled with this in the past. sometimes it works the first time, sometimes it takes a few tries.
    either way, i read the manual as i go through it each time, but it is not that clear.
    Bay Stater and Patrick Wong like this.
  5. fuzzy1
    10,667
    My 2012 manual says to turn Power to ON mode. I think I usually go all the way to normal Ready, pressing brake pedal to start. But now that you ask, my memory is scrambled.
    Raytheeagle and Patrick Wong like this.
  6. Mendel Leisk
    42,174
    ^ From page 428. My take:
    1. Turn car off with Trip A showing.
    2. With foot not on the brake, press-and-Hold MPH/KPH button and then push Power Switch twice (make the car "ON").
    3. Continue to press-and-hold MPH/KPH button, until odometer reads 000000. Hopefully...
    (We don't have this fun in Canada. :))
  7. bisco
    52,683
    'keep pressing' :p that's where i lose it
  8. bisco
    52,683
    how about:
    1) make car ready
    2) set trip meter to trip a
    3) power down
    4) press and hold the mph button, and press the power button
    5) continue holding mph button until trip a read 000000 and the mid indicates the reset is complete
    6) no wonder i'm :confused:
  9. Raytheeagle
    Raytheeagle Senior Member
    11,267
    15,525
    Bay Area, California
    2019 Prius Prime
    You forgot to pat your tummy while standing on one leg:ROFLMAO::ROFLMAO::ROFLMAO:.
    I just did this on our 2010 and when it comes up, make sure it is on Trip A before you shut the Prius down again. Then upon the next start attempt (like putting it into Ready mode), with the brake pedal depressed, hold down the mph/kph button and press the start button once.
    Should see the bar for reset displayed.
    Good luck (y).
    Bay Stater, bisco and Patrick Wong like this.
  10. Patrick Wong
    18,210
    6,517
    Yes, I should see that bar, but do not.
    Bay Stater, Raytheeagle and bisco like this.
  11. bisco
    52,683
    why do they call it the oil change system when it comes on every 5k?
    Bay Stater and Raytheeagle like this.
  12. bisco
    52,683
    i don't see 'foot on brake' in mendels o/m screen shot
  13. Raytheeagle
    11,267
    15,525
    2019 Prius Prime
    Hmmmmm.
    Well here is the screen shot of the procedure I keep in the car, if this helps:
    It definitely works for our II model from 2010.
  14. Raytheeagle
    11,267
    15,525
    2019 Prius Prime
    Cross company sharing:whistle:?
  15. bisco
    52,683
    i don't see 'foot on brake' in your instructions either
  16. bisco
    52,683
    also, the first line is missing a word :rolleyes:
  17. Raytheeagle
    11,267
    15,525
    2019 Prius Prime
    Sorry, my picture taking is a bit poor:oops:.
    But you get the idea;).
    I know it is missing the foot on brake, but I just hold the mph button down while I am starting the car normally.
    Worked last week, but I have to figure this out on the RX450h as that just popped up today the wife is telling me now:cool:.
    Something to investigate this evening(y).
    Bay Stater and bisco like this.
  18. Raytheeagle
    11,267
    15,525
    2019 Prius Prime
    Ok so I had to go pick up dinner so I tried 2 different ways and got it to work both of them:):
    1. Pressing the mph button and then press the start button twice
    2. Pressing the mph button, holding down the brake pedal and pressing the start button once
    So there appear to be options (y).
  19. bisco
    52,683
    now you're just trying to make patrick feel inadequate
    Bay Stater, Grit and Raytheeagle like this.
  20. Raytheeagle
    11,267
    15,525
    2019 Prius Prime
    I’m giving him “options”:p.
