2015 Maintenance Required Message reset
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Patrick Wong, Dec 28, 2018.
  1. Mendel Leisk
    42,176
    If you don't press the brake, you avoid the car starting up, is all?
    Bay Stater and Raytheeagle like this.
  2. fuzzy1
    10,668
    Because when they released the Gen3 in 2009, the oil change interval was 5k miles, at least in the U.S. Only months after release was it boosted to 10k, but the firmware was never updated. Apparently, not even in later Gen3 model years, with that tire rotation excuse for maintenance.
    Bay Stater, bisco and Raytheeagle like this.
  3. Raytheeagle
    Raytheeagle Senior Member
    11,267
    15,525
    Bay Area, California
    2019 Prius Prime
    Yup ;).
    But if you do it quick enough, it doesn’t matter (y).
    Bay Stater and Mendel Leisk like this.
  4. Patrick Wong
    18,210
    6,517
    Here is the resolution to this issue: I pressed the DISP button (on the right side steering wheel controls) to bring up the display with the traction battery state of charge gauge and the power flow arrows between the engine, battery and front wheels. Then I could reset the maintenance required timer using the normal process.
    The reset procedure would not work with the display showing the Maintenance Required message. My guess is that the underlying display was the screen that shows only the current date on the display.
  5. bisco
    52,685
  6. JC91006
    16,923
    8,634
    There was another member with a similar issue, he had a 2015 plug in. Maybe they changed the programming/firmware on the 2015
  7. Organic_Planter
    Organic_Planter New Member
    Mid-Atlantic
    Tried the display Trip A, hold the MPH/KPH button and simultaneously press the power button twice (foot off brake) method. It did not work for me if my foot was off the brake. DID work if I depressed the brake while holding the MPH/KPH button and then hitting the power button twice. Went like a charm. Had an oil change a couple of days ago and they didn't reset. Thanks for the advice!
    bisco and Mendel Leisk like this.
  8. Mendel Leisk
    42,176
    I'm just thankful we don't have this in Canada. :whistle:
    Bay Stater and bisco like this.
  9. CR94
    CR94 Senior Member
    2,794
    1,227
    Northwestern S.C.
    How do you do it up there?
    It's easy! I reset it about 3800 miles after the last oil change+reset. That way, the gentle preliminary reminder pops up at about 8300, then the sterner, more annoying one at 8800 if I still have not changed the oil.
    Bay Stater likes this.
  10. Mendel Leisk
    42,176
    We don't have a reminder. Life goes on lol.
    Bay Stater and RMB like this.
  11. Jonathan Cole
    Jonathan Cole TheRealJoCo
    Orlando, Florida
    Dude!! This helped me so much. Thanks a ton!
