2015 Prius 4 No Audio Output
Discussion in 'Gen 3 Prius Audio and Electronics' started by Clarissa, Nov 5, 2020.
  1. Clarissa
    Clarissa New Member
    San Diego
    Hey Everyone!
    So about 3 nights ago the audio output in my car ceased altogether. Meaning, everything else works Per-fect-ly fine! But
    1. No sound it being outputted.
    2. Volume toggle no longer displays numbers at all.
    3. Touchscreen menu items no longer beep when pressed.
    I opened the users manual and checked the 3 main audio fuses but none of them show any issue.
    Eager to receive any assistance
    52,904
    hard to know definitively. you're probably going to have to pull the unit, check the connections and if they are good, replace it.
    unusual for a 2015
    Clarissa likes this.
  3. Grit
    Grit Senior Member
    6,577
    4,231
    Wilkes Land
    Disconnect the 12v battery lead to reset to factory default If that doesn’t do then it’s kaput.
  4. BurkPhoto@aol.com
    56
    High Point, North Carolina
    The 2015 Entune? It is a known P.O.S.!
    My wife has a 2015 Prius v Four with the Entune. We LOVE everything ELSE about the car. But the Entune system re-boots itself randomly. From what I've read, about the only solution worth anything is ripping it out and replacing it with an aftermarket unit. Toyota laid a buggy egg when they used this garbage. They don't do that very often, but when they do... ugh!
    These units do all sorts of strange things. Different people describe different ways in which the Entune is "possessed" by evil spirits. I wish I had better news for you.
    You MIGHT want to try this:
    Entune Audio Head Unit Software Update (Panasonic) download / entune-audio-head-unit-software-update-panasonic.pdf / PDF4PRO
    It didn't change a thing for us.
    #4 [email protected], Nov 6, 2020
  5. Clarissa
    Clarissa New Member
    San Diego
    Hopefully not. I suspect it has to do with the 12v Battery. I read they have a lifespan of 6 years if well maintained or something. I bought this vehicle last week. Seems like she's been sitting for a while. Thanks for your insight!
    Hoping here lies the solution. I'll give it a shot and see what happens. Thanks!
    I'm not sure if it's Entune. Is that what the 2015 Prius 4 comes with? I know mine came with JBL speakers which, I was so sad when I had to drive from San Diego to LA with NO MUSIC from those powerful things =,(
    I'll double check the software and come back to this. Thankyou!
    #5 Clarissa, Nov 6, 2020
  6. Clarissa
    Clarissa New Member
    San Diego
    Here what im looking at
  7. bisco
    52,904
    was that all there when you bought the car?(n)
  8. Clarissa
    Clarissa New Member
    San Diego
    Yes absolutely. Then it one morning it just gave out. Im confident this is an easy fix, i jsut dont want to attempt to fix the wrong thing and waste money
  9. Clarissa
    Clarissa New Member
    San Diego
    I've been driving around just like this as im planning to head to a Toyota dealer
  10. bisco
    52,904
    i would start by removing all the aftermarket stuff
  11. ItsBROSEPH
    ItsBROSEPH Junior Member
    Bay Area
    2013 Prius Plug-in
    I just started having this issue! Same symptoms. Have you fixed this yet? I'm debating if I should replace the the 12v.
  12. Clarissa
    Clarissa New Member
    San Diego
    Dooode. I haven't fixed it yet. I went to the Toyota dealer and they wanna tax me $3k to fix it. It was at that point that I decided to go to Walmart and just buy Bluetooth speaker. I'll figure it out someday
  13. Clarissa
    Clarissa New Member
    San Diego
    Please do keep me updated! We're in this together man
  14. ItsBROSEPH
    Bay Area
    2013 Prius Plug-in
    I'm going to take the 12v out and test it and report back!
    Genio951 and Clarissa like this.
  15. Grit
    Grit Senior Member
    6,577
    4,231
    Wilkes Land
    There's an audio ampplifer under the passenger seat that handles the audio output to the speaker, it's shielded a plastic covering. Since you have a four package it has the jbl package; external amp. The amp may need troubleshooting.
  16. Clarissa
    Clarissa New Member
    San Diego
    Im looking at it now . I cant imagine what needs troubleshooting but at least now I know where to find the amp ⚡
  17. Clarissa
    Clarissa New Member
    San Diego
    GUYS!!! I BRING BACK!!! FRUIT FORR THE VILLAAGE!! (I've been slowly cutting out coffee)
    I visited a passionate mechanic in Mexico. He used his handheld diagnostics tablet on my Prius and a specific code popped up:
    B15C3 (Diagnostic Trouble Code (DTC) is stored when a malfunction occurs in the speakers)
    Possible Causes
    Faulty Speaker
    Speaker harness is open or shorted
    Speaker circuit poor electrical connection
    Faulty Navigation Receiver Assembly
    Faulty Stereo Component Amplifier Assembly
    Read more: B15C3 TOYOTA Speaker Output Short
    I was told to visit a car audio specialist. If you know any in San Diego county please shoot me their info!
    This is by far the BEST lead and I thank you all for responding!
    Genio951 likes this.
  18. kanobe
    kanobe Junior Member
    MO, USA
    I have the same issue in my 2012 Prius 4. Audio just totally stopped working, but everything else is fine. Just got back from the dealer, who ran diagnostics and got the B15C3 code as well. They told me mine has a short in the amplifier, and they quoted me close to $1,300 to replace. Planning to go to a local car audio place to see if I can get something better for cheaper.
    Clarissa, bluespruce and ItsBROSEPH like this.
  19. bluespruce
    bluespruce Member
    79
    72
    New England
    2020 Prius Prime
    I had the same happen to my 2015 Prius. I went to Best Buy and they offered free installation if you buy a head unit from there. Worth checking out. They did a good job on a unit with wi-fi carplay and android auto.
    Clarissa and Genio951 like this.
  20. Clarissa
    Clarissa New Member
    San Diego
    Nice nice! Yeah it turned out I just had to replace the stinking thing . Bought a used (2012 i think) amp on ebay for around $300. It goes out if the volume is too high & overheats and shit but. Works otherwise.
