2015 Prius Brake Booster/Actuator Questions
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by 15SuperPrius, Nov 13, 2022.
  1. 15SuperPrius
    15SuperPrius Member
    174
    65
    FL
    Hi folks,
    As of recent I've noticed that the brake actuator on my car makes the pressurizing sound every 10-12 seconds constantly during driving, and continues to do so for a few minutes after the car has been turned off; this is accompanied by a spongy brake pedal that allows me to peg it to the floor if I apply enough force. I believe brake actuator failure is a well-known problem on the 3rd gen Prius, and based on what I've read, the car qualifies for a free replacement as long as it has under 150k miles and the in-service date was less than 10 years ago. Is this correct information? If so, the fix should be covered by Toyota given that my career meets the criteria.
    I checked the brake fluid level and it is slightly under the middle/normal line (pretty much in the center between the min and max lines) eliminating the possibility of a leak. I believe the actuator likely has an internal pressure leak, leading to the spongy brake pedal and the constant actuator sound every 10-12 seconds.
    Thanks!
    52,785
    you can pull up the warranty extension at toyota.com/owners to see if you need a trouble code to qualify, or just check with dealer service
  3. ChapmanF
    18,960
    Do you have any brake-related warning lights yet?
    I think you've got the right diagnosis by the sounds, but for eligibility under the ZJB customer support program, one of four specific trouble codes should be showing. Probably that won't take long at this point.
