2015 Prius C AC issues
Discussion in 'Prius c Main Forum' started by SCT431, Nov 18, 2019.
Tags:
  1. SCT431
    SCT431 New Member
    Long Beach, CA
    2015 Prius c
    I recently started having an issue with the AC - its no longer blowing cold air. Couldn't see much, thinking maybe a belt issue. But then again I didn't really know what I was looking for. is there a dedicated fuse that I may have blown, or is this a bigger issue that will cost me a small fortune?
    Any ideas on where to start would be greatly appreciated.
    thanks!
    52,855
    welcome!
    the a/c compressor is electric, no belt. its a complicated system that really need a hybrid competent a/c shop to diagnose. could be simple or complicated.
    do the radiator fans come on when you turn on the a/c?
  3. Leadfoot J. McCoalroller
    8,288
    7,802
    Pennsylvania
    2018 Prius c
    I'm not sure if a 2015 has the new-style control panel or the old-style control panel. The old one has a bug where the "off" button can get stuck partway down, and fakes the thing into turning off your A/C immediately after you turn it on.
    You might try cleaning around the edges of the button with an old dry toothbrush, or maybe pulling up on the button face with a loop of adhesive tape.
    If it isn't that? Yeah, gather the small fortune...
  4. davidc83
    davidc83 Member
    116
    51
    Scottsburg, Indiana
    2015 Prius c
    If it blowing air, but doesnt get cold, probably time for a refrigerant replacement.
    SM-S367VL ?
