2015 prius c hybrid inverter cracked casing
Discussion in 'Prius c Care, Maintenance and Troubleshooting' started by CARSFAN4, Sep 6, 2024.
  1. CARSFAN4
    CARSFAN4 Junior Member
    62
    Los Angeles
    2015 Prius c
    I lost all the oil from the hybrid engine due to a night accident when I climbed over the curb in a dark intersection with a narrow road split.
    I am now waiting for the mechanic in the morning to check how bad is the hybrid engine Crack on the bottom casing.
    Question: do you think that there was also internal damage to the hybrid engine parts???
  2. MAX2
    MAX2 Senior Member
    1,436
    490
    101
    Third planet from the Sun
    Impact speed?
    How quickly did you stop after hitting an obstacle?
    There may be no mechanical damage.
    If the movement was stopped, the liquid did not have time to leak out quickly.
    It is better to check the high voltage windings of the MG for leaks with a good megohmmeter.
    CARSFAN4 likes this.
  3. John in Vermont
    John in Vermont Junior Member
    50
    Rochester, Vermont
    2018 Prius c
    Scraping the bottom shouldn't have damaged the internal parts of the engine. If the car ran for more than a minute or two without oil then the bearings or cylinder walls may be badly damaged.
  4. CARSFAN4
    62
    Los Angeles
    2015 Prius c
    I was driving with 35 m/hr and both of the left side rims were bent. I stopped after I hit the curb. The engine didn't start and there was a note on the dashboard that I have to check the hybrid motor.
    Below the hybrid motor block there was leaking all the oil.
    Did u see the photos I attached??
    One Pic shows the torn corner of the motor block and I also reached there to feel the missing piece of the block casing.
    My next question is this:
    Is there any way that I can disconnect the hybrid motor from the main power so I can drive only with the gas engine???
    I don't know if the computer module will sense the hybrid motor disconnection so it can cut the gas engine start up.
    Thanks for your cooperation!!!!
  5. CARSFAN4
    62
    Los Angeles
    2015 Prius c
  6. ChapmanF
    19,006
    No. The electric motors are integral to the transaxle, the transaxle is what has lost its oil, and without the motors participating, the transaxle doesn't transmit any power, not even from the engine.
  7. ChapmanF
    19,006
    JohnPrius3005 likes this.
  8. John in Vermont
    50
    Rochester, Vermont
    2018 Prius c
    If the engine stopped immediately, you probably haven't done any internal damage to the engine or driveline. To get the car running again, you will have to replace the accident damaged part or parts, which will probably be moderately expensive to do.
    You need to have a knowledgeable mechanic do a very thorough inspection of the car before you start any repairs. Beyond the obvious damage to the transaxle and wheel rims, there may be damage to the suspension and the body where the suspension mounts. In short, it may not be worth it to repair the car. If you carried comprehensive insurance on the car, the repairs should be covered by your insurance carrier.
  9. Mendel Leisk
    42,323
    Can you take some more demonstrative pictures? Sorry, but I can't make head-nor-tail out of those you've posted.
    Have you checked the dipstick?
    Any liquids on the ground?
    My hunch, based on the dashboard notice, is you've dislodged some electrical connectors.
  10. Tideland Prius
    16,678
    *Threads merged*
    Brian1954 likes this.
  11. Sonic_TH
    Sonic_TH Active Member
    575
    96
    Puerto Rico
    2016 Prius c
    The transaxle housing is broken, that's not the engine seems like. I don't think it's possible to even weld on that kind of material, the only solution is to replace the transaxle housing sadly.
  12. CARSFAN4
    62
    Los Angeles
    2015 Prius c
    Yes, thanks. U r right I found the same answer on Google: additionally it can damage the battery.
  13. CARSFAN4
    62
    Los Angeles
    2015 Prius c
    No, the engine stopped running immediately. But it seems to me u r confusing the gas engine with the hybrid Inverter motor. If u look over the pics I attached u can see that the oil leaked from the inverters cooling pump.
  14. CARSFAN4
    62
    Los Angeles
    2015 Prius c
    Is the transaxle something as the automatic transmission, or it is like a planetary axle to transmit the motion to the wheels??
    Thanks
  15. ChapmanF
    19,006
    Front-wheel drive cars generally have a 'transaxle'. The word is a portmanteau of 'transmission' and 'axle', where 'transmission' is the thing that bolts to the engine and can convert the engine speed and torque to the needed output speed and torque, and 'axle' is the thing that has a final, fixed-ratio speed-reducing torque-multplying gear and a differential to split the torque two ways, and has two wheel drive axles sticking out.
    A 'transaxle' just combines both of those things in one case. It bolts onto the engine, and has two wheel drive axles sticking out.
  16. CARSFAN4
    62
    Los Angeles
    2015 Prius c
    Yes indeed, I took pics of the block hole aprox. 1" tall and 0.5" wide. I want first to try and cut it straight w.a circular saw and a carbide tipped blade for aluminum cast. Then cut 2 small aluminum bars to cover and glue the whole. The transaxle works fine.
  17. CARSFAN4
    62
    Los Angeles
    2015 Prius c
    Thanks, but before this I need to try to plug that's 1"x0.5" hole with aluminum bars and glue them with JB WELD 24 Hours adhesive. I saw it on YouTube.
  18. Sonic_TH
    575
    96
    Puerto Rico
    2016 Prius c
    I don't know man, it might still leak
