2015 Prius c redesign/changes?
Discussion in 'Prius c Main Forum' started by vernon birdman, May 12, 2014.
  1. cyclopathic
    cyclopathic Senior Member
    3,292
    547
    2014 Prius c
    this is 8" 600wt sub.. Enclosure is 7.2 x 14.4 x 12 inches. I haven't measured but I think it may fit.
    600wt is not much but since I am planning to pair it up with speakers which are rated down to 30Hz, it may be enough? will see.
  2. mertechperformance
    mertechperformance Active Member
    532
    126
    Nor-caL
    Can almost guarantee you it will not.
  3. mertechperformance
    532
    126
    Nor-caL
    My amps are less than 3" tall and have less than 2" clearance between the top of them and bottom of seat.
  4. mertechperformance
    532
    126
    Nor-caL
    Went and checked again there's more room than I thought but a smidge over 7" I don't think so. If you can easily return the box I say try it. If not then I wouldn't risk it. There may be a company that makes a stealth box for it.
  5. mertechperformance
    532
    126
    Nor-caL
    And 30hz probably won't sound too impressive out of 6.75"s
  6. cyclopathic
    3,292
    547
    2014 Prius c
    TS-SW2002D2 is rated at 20-200, and TS-A16xx are 34-30k Hz. I am thinking about blending them at about 50-70Hz. I need linear response for the type of music I am listening to, so don't really need overemphasized lows. In home theater Audyssey set up X-overs at 55-70-95Hz but turned surround down to 85 as it was getting too directional and was creating strange surround effects.
  7. mertechperformance
    532
    126
    Nor-caL
    Yeah, doesn't mean they work well at that frequency. Especially in a door aka unsealed.
