2015 Prius C remote fob not working
Discussion in 'Prius c Care, Maintenance and Troubleshooting' started by TimoSpenter56, Oct 15, 2023.
  1. TimoSpenter56
    TimoSpenter56 Junior Member
    Chicago, IL
    2015 Prius c
    Hi. I have a remote key fob that looks like the image below, and none of the buttons work even after I replaced the battery. I have two keys and replaced both batteries and they are both not working. Other than this issue, I’ve been driving the car without any other problems. However, I feel a little inconvenienced I can’t use the remote fob when I’m in a hurry to get in the car, especially living in a sketchy neighborhood.
    Based on my research so far, I think I should check the fuse next and have read the fuse box diagram, but not sure which fuse is specific to this issue. I’m including the fuse box diagram link below, and would someone be able to pin point which fuse should be checked? Thank you kindly.
    Fuse Box Diagram Toyota Prius C (2012-2017)
  2. Leadfoot J. McCoalroller
    8,259
    7,761
    Pennsylvania
    2018 Prius c
    Do the power locks still work from the controls on the door armrest?
    There isn't a fuse that only supplies the remote receiver.
  3. TimoSpenter56
    Chicago, IL
    2015 Prius c
    yes, the power locks still work from the controls on the door armrest.
  4. TimoSpenter56
    Chicago, IL
    2015 Prius c
  5. DonutRobot
    DonutRobot Junior Member
    Ohio
    I have the same issue on my 2013 C. Don't have a solution.
