2015 Prius c tire
Discussion in 'Prius c Main Forum' started by TimoSpenter56, Sep 25, 2022.
  1. TimoSpenter56
    TimoSpenter56 Junior Member
    Chicago, IL
    2015 Prius c
    I need to replace all four of my tires for Prius c 2015 soon, and was quote approximately $600 for 15", and $500 for 16" tires. Would someone please educate me on why I save $100 to go with the 16", and what the difference would be in terms of performance?
    The original tire that came with my car is 15".
    What are the pros and cons of the different choices?
    The person who quoted me couldn't explain what the difference is - he just entered my car model in a computer and said those are the two options I have.
  2. Leadfoot J. McCoalroller
    8,274
    7,775
    Pennsylvania
    2018 Prius c
    I don't think you actually have a choice here, just a confused salesperson. To be fair, lots of fit application guides and databases seem to have incorrect info for the c model
    Your car should have size 175/65R15 tires on it. Go read the sidewall to doublecheck. That last 15 in the size means 15".
    Using 16" tires would require 16" wheels. This was a factory option available exclusively for the Four trim. If I read it right, yours is the One trim, making it very likely that you need the 15" tires. The salesperson most likely looked it up in a database, saw something that said the car might have 15" or 16" wheels and didn't have enough info to narrow it down further.
    Confirm the size molded into the sidewalls of your current tire before ordering anything- but I think you are extremely likely to see the stock 175/65R15 on your car.
    ...and if you don't mind, maybe ease up on the duplicate posts? I reported them to the moderators so they can clean up after you, but it's really better if nobody has to go through that hassle.
    #2 Leadfoot J. McCoalroller, Sep 25, 2022
  3. TimoSpenter56
    Chicago, IL
    2015 Prius c
    Yep, I see stock 175/65R15 on my car. Thank you for the clarification!
  4. John in Vermont
    John in Vermont Junior Member
    50
    Rochester, Vermont
    2018 Prius c
    If you have 15 inch rims and want to use 16 inch tires you will have to buy four new rims that will cost several hundred dollars.
    The 16 inch tires were cheaper because they were possibly not the same type of tire and not from the same manufacturer as the 15 inch tires you were also given a quote on. Additionally, there are supply chain problems for the tire industry and prices on certain tire sizes have risen because they are hard to find. The tire sizes for Prius cars are fairly unique, so that can only make the tires even harder to find and will make them more expensive.
    The person who quoted you on both tire sizes without asking what tire size the car currently has was clueless. I would start out by asking for quotes from a few different tire dealers and stay away from the place you first went to. You are allowed to ask questions if you don't fully understand a quote.
