2015 Prius C - trouble starting
Discussion in 'Prius c Care, Maintenance and Troubleshooting' started by arothmd, May 16, 2023.
  1. arothmd
    arothmd New Member
    Chicago, IL
    2015 Prius c
    2015 Prius C. Intermittently, when I put the key in and turn it on, all the lights light up as usual, except the READY light. All electronics work (radio, lights, etc.) but the motor doesn't go. Started about a year ago, was occurring about once a month but is now more frequent - almost daily. But never twice in a row. If I take the key out and wait 2 minutes and repeat the normal start-up process, the READY light comes up and the car starts. If I try sooner than 2 minutes, it doesn't work. I take multiple trips throughout the day, both short and long -- no specific pattern. It is not the battery. Have taken it to dealer, but it doesn't happen in front of the dealer so they cannot diagnose. Please advise. Thank you.
  2. Leadfoot J. McCoalroller
    8,294
    7,812
    Pennsylvania
    2018 Prius c
    I thought the Three trim used a pushbutton start system? Or perhaps that wasn't true until a later model year?
    Can you clarify whether yours has a traditional ignition lock on the side of the steering wheel, or a pushbutton starter?
  3. arothmd
    arothmd New Member
    Chicago, IL
    2015 Prius c
    No button; it has a traditional key ignition on the side of the wheel post.
  4. Leadfoot J. McCoalroller
    8,294
    7,812
    Pennsylvania
    2018 Prius c
    Then my first guess is a dirty or failing contact in the actual ignition switch there on the steering column.
    It sounds like the increase in incidence may soon make it easier to demonstrate at a repair shop.
  5. Toothpicker
    Toothpicker Junior Member
    31
    CT
    Same issue with my car. it is 2012 pc 2. I highly doubt this is a mechanical issue with the ignition switch. More likely it can be related to not competed prep cycle. Either weak battery or ….
  6. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,804
    2017 Prius c
    Does that model also require your foot on the brake to do a full "start" ?
    Could be a sign of a weak 12 V battery too......not properly booting up some of the
    electronic boards.
  7. Leadfoot J. McCoalroller
    8,294
    7,812
    Pennsylvania
    2018 Prius c
    No need for foot-on-brake in our twist-key Two, but I can't speak for older model years.
    Foot naturally goes on the brake about then anyway because it is needed to shift out of Park, but that's just coincidental.
  8. rjdriver
    rjdriver Active Member
    411
    172
    Rhode Island
    Sounds like the 12v battery to me. Especially if it's the original. Although that 2 minute wait you describe makes me think there might be something else going on as well.
    But I'm really curious how you got a trim 3 without push button start.
