2015 Prius II - Front Seat Stock to Power/Lumber OEM Prius IV/V DIY
Discussion in 'Gen 3 Prius Accessories and Modifications' started by 50MPGPAUL, Nov 11, 2014.
  1. forrest_fire1
    forrest_fire1 Junior Member
    27
    Oregon, Roseburg
    Great question, did this question ever get answered? Did you happen to solve it yourself?
  2. Darthchoke
    Darthchoke Junior Member
    Los Angeles
    That’s a good question and been waiting for a answer as I’m planning of getting the Lexus ct200h seats
  3. Coots
    Coots Member
    62
    25
    Hailing from parts unknown, Iowa
    @FriedCells
    @tallprius
    Did you ever test the heat with your Lexus seat? I live in the Midwest and I am curious to know.
    Also, the clearance issues for the seat being too low, is that when the seat is adjusted all the way down? If the seat is in a raised position, are there still clearance issues with the box underneath the seat?
  4. Coots
    Coots Member
    62
    25
    @FriedCells
    How does the ct200h seat back height compare to the Prius? It looks like the Lexus seat back may be a bit shorter?
  5. PriusHead05
    PriusHead05 Member
    318
    If I remember right there was a thread about that. They kept going back and forth and I think the finally came up with the Lexus seat was an inch shorter.
  6. PriusHead05
    PriusHead05 Member
    318
    I'm guessing that doesn't matter since the track is what moves back and forth as well. The track doesn't go up and down with the seat (I think?).
  7. PriusHead05
    PriusHead05 Member
    318
    I am planning on getting the CT seats as well, but I read in another forum about the Lexus seat using two positive while the Prius seat only has one. They also said you need to splice the positives. Someone else asked what that meant, but there was no response. Which positive and where are we splicing?
  8. PriusHead05
    PriusHead05 Member
    318
    I just swapped my driver's seat for a CT200H seat. I am going to be making a separate thread that's actually titled fro a CT200H seat so it's not confusing.
  9. black_jmyntrn
    black_jmyntrn Senior Member
    1,721
    404
    2013 Prius Plug-in
    wel.. i know this is gen 3 area and now im gonna try to fit a Gen 4 Prime seat into the Gen 3... was looking for where someone mentioned the colors on the wire harness and such.,
