2015 Prius in the garage
Discussion in 'Newbie Forum' started by woodrow bryan, Mar 17, 2023.
  1. woodrow bryan
    woodrow bryan Junior Member
    Decided to try a Prius. My wife loves it. I like it. Getting to like it more. It's a level four trim package. 147K miles.
    Montgomery and mikey_t like this.
  2. douglasjre
    douglasjre Senior Member
    2,247
    751
    Null, NL
    Change the trans fluid, oil, antifreeze and save money for a head gasket replacement
    woodrow bryan likes this.
  3. Mendel Leisk
    42,296
    Clean the EGR system, including intake manifold, ASAP. See first 2 links in my signature. On a phone, turn landscape to see sig.
  4. woodrow bryan
    The oil, coolant and an upgraded head gasket plus EGR and throttle body just performed. Only thing left is the ATF fluid.
    Montgomery, mikey_t and Mendel Leisk like this.
  5. bisco
    52,803
    congrats and welcome!
  6. Mendel Leisk
    42,296
    Wow. You did it, or previous owner?
  7. woodrow bryan
    Dealer that specializes in Prius. Has a 1 year warranty on the engine work. Also new tires. Not sure why the transmission fluids were not changed. They agreed it should be done and was probably an oversight. I went to the closest Toyota dealership and picked up my supplies for the transmission fluid change. Crush washers, oil pan drain plug washers, ect... I also purchased a new HV air filter/screen that is installed on the exterior of the HV air vent instead of behind it. What a pain. So I removed the internal screen and snapped the external one on the vent. Much easier to clean and is visible instead of out of sight out of mind.
  8. DavidDavid
    DavidDavid Junior Member
    29
    Is cleaning the EGR system with the Manifold keep Prius from having the head gasket issue?
    mjoo likes this.
  9. Mendel Leisk
    42,296
    That’s what I’m betting.
  10. DavidDavid
    29
    I totally agree, ones the engine starts knocking due to the EGR valve and intake manifold get stopped up, they have to be cleaned right away, if not they will cause a head gasket issues later.
  11. bisco
    52,803
    tampa hybrids?
  12. woodrow bryan
    Yes sir. Mike took care of us.
  13. Montgomery
    Montgomery Senior Member
    2,254
    2,242
    Orange County, CA
    2015 has the upgraded pistons and rings so with the repairs you have done, you should be good to go. I drive a 2015. Had the full monty done at 65k and installed Oil Catch system.
    Mendel Leisk and bisco like this.
  14. woodrow bryan
    I think so as well. Had the transmission serviced today. Fluids were pitch black. No hint of the original color. Should be good to go now. Hard to believe that didn't hurt the transmission. Keeping fingers crossed.
  15. bisco
    52,803
    a lot of people say that, i think it's normal
    Montgomery likes this.
  16. Montgomery
    2,254
    2,242
    Orange County, CA
    Transmission fluid is made to absorb impurities over time. It also makes a great cleaning fluid for auto parts in general.
