2015 prius multi-function display issues
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Azshire, Apr 26, 2023.
  1. Azshire
    Azshire New Member
    Denver
    SE
    Not sure if anyone has come across this or know a fix to it.
    But the wife went to pick up the kid from school, everything worked fine. Turned the car off, went inside, came back and the multi-display screen was just black with the word TOYOTA displayed across it.
    No music, no sound at all, no main screen. You can change the volume via button and see that change on the screen. You can go into settings and select stuff from there like Bluetooth or vehicle settings. But the main screen where you select the radio stations and such doesn't appear. Even tried using the mode button the steering wheel, but nothing seems to work.
    Tried looking up some kind of solution on web, but to no avail. Was hoping someone here might have a fix.
    Thanks in advance
    Azshire
    52,536
    could be a gonner, but try disconnecting the 12v negative for a minute to reset everything
