2015 Prius on replacement battery not getting good mpg
Discussion in 'Gen 3 Prius Fuel Economy' started by Roger Elliott, Feb 2, 2026.
Tags:
  1. Roger Elliott
    Roger Elliott Junior Member
    Redding CA
    Hi Folks
    I have a 2015 Toyota Prius with a replacement battery (actually 2nd replacement - first replacement was defective and replaced for free). I am running stock dimension tires but they are by a company called Sailun (Trezzo h408 size 195/65). Since the 2nd replacement, in my usual commute of 10miles, stop and go with some hills, I've been lucky to get 40mpg. Usually I would get 42-45 but now I'm getting like 36-39. The car has about 150k on it. Weather is pretty mild usually except in summer when it hits 100 or more. Any ideas?
    Thanks
    Roger Elliott
  2. ASRDogman
    ASRDogman Senior Member
    8,066
    4,089
    2nd replacement? So you got a used battery? Never worth it.
    You need the Sodium Ion NEW battery pack.
    Never heard of that brand of tire. Tires are important to fuel mileage.
    What tire pressures are you running?
    Both will highly effect mpg. Cooler weather effect mpg also.
  3. indel
    indel Member
    283
    89
    Northwest Indiana
    Are these battery replacements OEM? Were they replaced by the dealership? Post some results from Dr. Prius app or Hybrid Assistant.
  4. Mendel Leisk
    42,349
    Just to clarify: you replaced the hybrid battery, or 12 volt battery?
    Off-topic, but if you haven’t: I would clean the EGR (Exhaust Gas Recirculation) system as soon as possible, and replace engine water pump and thermostat.
  5. VelvetFoot
    VelvetFoot Senior Member
    1,408
    545
    New York State
    2026 Prius
    So, what do the tires have to do with it?
    You did something, battery, tires, both at the same time? Correlation to cause and effect?
    This is actual mpg, miles/gals, full tank?
  6. BiomedO1
    BiomedO1 Senior Member
    4,610
    2,416
    Left Coast
    Are these Toyota guess-o-meter numbers or manually calculated tank to tank averages.
    It's been pretty cold and rainy in Redding and we know how weather affects these cars. Unless you do an apple to apples comparison, under the same circumstances by adjusting only ONE variable - it's difficult to make general comparisons.
  7. VelvetFoot
    1,408
    545
    New York State
    2026 Prius
    I thought I just said that.
  8. BiomedO1
    4,610
    2,416
    Left Coast
    I was typing when you hit the return key to post your response..... so I didn't see it.
    VelvetFoot likes this.
  9. VelvetFoot
    1,408
    545
    New York State
    2026 Prius
    I thought you had me on ignore, or something.:)
  10. Roger Elliott
    Redding CA
    HI there
    The numbers I gave were manually calculated at each fill up. Even with the cold and rain and so forth, I usually don't see such a drop in mileage
    Roger
    The Hybrid battery was replaced. The first one was dying slowly - like getting low 30's for mileage but the second died completely, told me not to drive etc. The EGR and water pump and thermostat replacement yo mentioned - those can effect mileage?
    Thanks
    Roger
    No, no. It was a new OEM battery both times. Didn't have to pay for the second one as it was covered by warranty. I thought about a Sodium ion battery but I read a lot of conflicting experiences and thought it would be better to wait till they've been around longer and have their issues sorted out. Yeah I've never heard of the tires either. Read some reviews but there wasn't much experience with them to get a good definitive review. Certainly no reviews about their mileage effects. I usually run 32psi.
    Thanks
    Roger
    They are OEM, but they were replaced by a local Hybrid Shop. Local dealership is way overpriced.
    #10 Roger Elliott, Feb 3, 2026
  11. ASRDogman
    8,066
    4,089
    I'd bet the oem hybrid battery had been sitting a long time, and the charge was low.
    That's really bad. 2 bad batteries? I take it they are used blocks, not new.
    You should tell them you want NEW blocks, not "refurbished/used" one.
    There is nothing wrong with the Sodium Ion battery. There are "those" that just like to argue and
    will complain about everything they can to pull others into their sad life they choose to live.
    I installed mine in September 2024. I've had NO issues. And this recent cold weather, it performed perfectly.
    It held the charge, and the discharge/charge cycles were the same in the cold as the heat.
    Tires make a big difference. You should get the ones that are designed for hybrids.
    I'm currently running the Hankook Kinergy PT (H737) tires and average 48mpg, without trying.
    And of course the Sodium Ion battery really helps the mpg.
    Toyota recommend 36 front and 32 rear. I run 38psi front and rear. Some run higher, but they the
    risk of over inflating then overheating could cause a tire failure.
  12. indel
    indel Member
    283
    89
    Northwest Indiana
    Unless you are talking about 'labor' at local dealership being overpriced, it makes no sense. I can't imagine a local hybrid shop giving you a brand new OEM for much lower price than the list price. So what did they give you exactly? Did you check receipts and did you get a toyota warranty documentation? Also, Toyota only gives 12 month warranty on batteries sold over the counter. The 3 year warranty is only when the dealership installs the battery.
  13. Mendel Leisk
    42,349
    No.
    With 150k and untouched EGR, head gasket failure is likely to happen, sooner than later.
  14. Roger Elliott
    Redding CA
    What does it cost to service the EGR typically?
    #14 Roger Elliott, Feb 15, 2026
  15. Mendel Leisk
    42,349
    Two places I’ve heard of are Tampa Hybrids and Hybrid Pit Stop (in Los Angeles). A Priuschat member (who worked a stint at TH) mentioned something like $600~800 USD.
  16. bisco
    52,858
    If you’re convinced that the shop put in a brand new oem, then the problem lies elsewhere.
    The original battery having gone bad on a 2015 is extremely unusual.
    A second going bad is almost unheard of.
    Ten years old, and 150k, there could be many culprits.
    Start with dragging brakes
