2015 Prius plug-in rebuild
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by Wenchen Yi, Jan 14, 2021.
  1. Wenchen Yi
    Wenchen Yi New Member
    NY
    2015 Prius Plug-in
    Hi everyone, I am new to the forum. I just bought a NYPD accidental car to rebuild. I will try to update my rebuild work every to record the whole process.
    D1 received the car
    Mendel Leisk, bisco and PA Prius like this.
  2. Wenchen Yi
    NY
    2015 Prius Plug-in
    52,804
    welcome!
    how many miles on her? looks like a fun project.
    all the best!(y)
  4. Vinagre
    Vinagre Junior Member
    23
    Los Angeles
    Hello Wenchen,
    I was going to post this for someone to help but you have all the goods right there. I have a plug in 2014, perhaps you could help me identify a connection from the hybrid battery.
    It is for the fan control, if you look on the back you will see it.
    Here some pictures
    I would be grateful if you could id this connection.
    Thanks
  5. Mendel Leisk
    42,296
    Am I right in guessing those pics are rotated 90 degrees, in particular the last one? And which direction is the rotation?
    Can you describe position and orientation of camera, help responders?
  6. Vinagre
    23
    Los Angeles
    the pictures are taken from above. Some are just zoomed in to see the connector up close.
    This is in between the two battery cooling fans.
    Thank you
  7. Vinagre
    23
    Los Angeles
    I just added new pics, perhaps they are better resolution, also the connector is with the black wire harness the orange is high voltage
    Thanks
