2015 Prius Rear Hath Problems
Discussion in 'Gen 3 Prius Main Forum' started by issjoe, May 6, 2025.
  1. issjoe
    issjoe Junior Member
    27
    seattle
    Sometimes my rear hatch doesn't open correctly. When I try to open the rear hatch, its not totally closed and will not open or close. I have to go inside the rear of car and release the latch manually.
    Does anyone know why this happens and how to fix it?
  2. frodoz737
    frodoz737 Top Wrench
    4,807
    2,561
    33
    Using the button under the ledge? FOB? Are your struts weak? More info needed.
  3. issjoe
    27
    seattle
    It's not a button it's the actual rear hatch assembly. It's accessible by removing a small panel and sticking your hand in and manually disengaging it. The fob locks and unlocks allthe other doors but doesn't lock or unlock the rear hatch. The struts are fine.
    52,863
    maybe the actuator burned out, bad fuse or wiring?
