2015 Prius V engine shaking when starting in the morning
Discussion in 'Prius v Care, Maintenance and Troubleshooting' started by Nye, Nov 7, 2024.
  1. Nye
    Nye New Member
    Asheville, NC
    2015 Prius v wagon
    My daughter has informed me that her 2015 Prius V has been making a strange shaking rattling noise when starting in the morning. Recently, I replaced the spark plugs after receiving a misfire code for cylinder 4 (P0304), but I didn’t replace the ignition coils at that time. Since then, the check engine light has not come back on, but this noise recently started?
    The car has about 195,000 miles on it, mostly highway driving. My question is whether I should replace all the ignition coils or just start by replacing the one on cylinder 4.
    Also, could anyone recommend a good brand for long-lasting coils? I’ve seen Denso recommended, but they are not cheap.
    I'm a bit concerned after reading forums where this issue seems common in Priuses, and some owners have faced costly repairs. I'm hoping to avoid going down that path if possible, so any advice would be greatly appreciated!
    Thanks in advance for your help.
  2. rjparker
    rjparker Tu Humilde Sirviente
    11,133
    6,982
    Texas Hill Country
    If it clears up and runs fine after the cold start, you need to check for a head gasket leak that has those exact symptoms. A borescope is the only reliable method in early stages.
    Waiting until you have large coolant losses or white smoke can cost you the engine.
    Car Care Nut HG Borescope at 7:40
  3. Carall
    Carall Active Member
    316
    104
    Harrisonburg, VA
  4. Mendel Leisk
    42,369
    Fugedabout plugs and coils; it’s head gasket failure. If you stick with it be sure to clean the EGR system too, including the EGR passages in intake manifold.
    first 2 links in my signature relate to EGR cleaning, last is full engine section form repair manual. On a phone turn it landscape to see signatures.
  5. Nye
    Nye New Member
    Asheville, NC
    2015 Prius v wagon
    The strange part is, after using B12 fuel injector cleaner, the shaking has stopped in the morning. I've been checking it daily in the mornings, and it's been starting fine. However, my daughter says it's happening later in the day, like after school or today when she volunteered for four hours. Could this still be a head gasket issue, or does it sound more like the EGR valve? I was hopeful that the problem was resolved, but now it seems to happen midday instead of in the mornings.
  6. rjparker
    11,133
    6,982
    Texas Hill Country
    An egr system won’t cause the severe stumbling and rattling of a hg leak. It might stick open at idle causing a slightly rough engine. There is a simple egr tube blocking technique to completely eliminate the egr.
    Car care Nut Egr video with block tube test
    An early stage hg leak depends on a fully warmed up engine pressurizing the coolant system prior to shutdown. This pressure pushes a few drops of coolant into the cylinder over a few hours causing the extreme rattling caused by temporary misfires. Sometimes it does not happen; likely due to valve state at shutdown.
    A borescope test is needed.
  7. Mendel Leisk
    42,369
    It's both, a cascade effect. Long neglect of the (poorly designed and insufficiently tested) 3rd Gen EGR system leads to carbon clogging, and to unevenly supplied (cylinder one typically starved first) and overly hot exhaust gas, engine overheats (unevenly), and head gasket succumbs.
  8. Leadfoot J. McCoalroller
    8,292
    7,808
    Pennsylvania
    2018 Prius c
    Do a borescope check soon. If you catch it early enough you can get out of it with just a gasket job.
    If left a while the next cheapest cure is a replacement engine.
