2015 Prius V Hybrid Indicator
Discussion in 'Prius v Care, Maintenance and Troubleshooting' started by ef817, Dec 16, 2017.
  1. ef817
    ef817 Junior Member
    2013 Prius v wagon
    Drove for six hours today and pulled off into a hotel parking lot. I restarted my car a few minutes after I stopped and an alert for Hybrid System Indicator came up. It didn't stay on, it didn't flash or buzz and I was able to drive the car. My thought is to let it rest for the night and see if it does it in the morning. Any ideas why this is happening? I have another six hours to go tomorrow and am wondering if it is safe to do so.
    52,862
    probably just a glitch. anything unusual about your driving, the weather or the topography?
    have you checked the oil, air filter, and battery cooling intake grille?
    what does an 'alert for the hybrid system indicator' look like?
  3. ef817
    ef817 Junior Member
    2013 Prius v wagon
    Just had the car serviced so oil shouldn't be the problem. It might be time to change the air filter. I'm at 26000 miles on the car.
    52,862
    30k according to the owners manual. maybe it's time you took more proactive interest in the maintenance?
    for all you know, the dealer might not have added enough oil.
  5. ef817
    ef817 Junior Member
    2013 Prius v wagon
    Quite possible. I will check it first thing in the morning.
    Raytheeagle and bisco like this.
  6. Sooner Al
    Sooner Al Active Member
    385
    340
    Oklahoma, USA
    2016 Prius v wagon
    Like this...
  7. bisco
    52,862
    thanks!(y)
  8. rdgrimes
    rdgrimes Senior Member
    1,740
    448
    New Mexico, USA
    2018 Prius Prime
    There has to be an error code recorded on that, someone just needs to read it. Maybe the battery vent was blocked or the like.
  9. ef817
    ef817 Junior Member
    2013 Prius v wagon
    None of those are what I saw. It simply says Hybrid system indicator and then it goes away.
  10. Sooner Al
    385
    340
    Oklahoma, USA
    2016 Prius v wagon
    How about this...
    As noted by @rdgrimes perhaps getting the codes would be helpful...
    Also get the Owners manual for your car to see if there is an illustration for that...
  11. bisco
    52,862
    the hybrid system indicator is simply one of the screens on the display. not sure what it means when the words pop up on the mfd for an instant.
  12. ef817
    ef817 Junior Member
    2013 Prius v wagon
    Me neither. It just pops up when I start the car and it disappears. I accidentally hit the EV mode button yesterday while I was driving, and I noticed that it pops up when I hit that again this morning.
  13. ef817
    ef817 Junior Member
    2013 Prius v wagon
    I checked the oil, hybrid system vent under the rear seat.
  14. ef817
    ef817 Junior Member
    2013 Prius v wagon
    Checked the oil, made sure the hybrid vent under the rear seat is clear.
  15. ef817
    ef817 Junior Member
    2013 Prius v wagon
    I’m thinking that it’s something that happens normally when I turn on the car and I never noticed it before.
  16. bisco
    52,862
    it very well could be.
